Making my own CCT
Old May 3, 2009 | 08:58 PM
superdutyd's Avatar
Making my own CCT
I'm just about finished making my own set. I still have to cut the other side but thats it. I made them from 6061-T6 aluminum 1" thick which I believe is 1/4" thicker than the APE ones. I wanted the adjuster bolt to have more threaded area. What type of carriage bolt do you guys think I should buy, stainless or zinc plated?
Old May 3, 2009 | 09:01 PM
superdutyd's Avatar
Here's a pic.
Old May 3, 2009 | 09:05 PM
Truckinduc's Avatar
Im using Stainless. Zinc plating will look like **** in a few years.
My CCT's are 3/4 6061 T6
Old May 4, 2009 | 08:38 PM
superdutyd's Avatar
made a little more progress today.
Old May 5, 2009 | 04:11 AM
JamieDaugherty's Avatar
Looking good! You should leave them aluminum. I'd go with an anodized finish if you wanted them to stay looking good. Steel is a lot heavier, although these parts are small it all adds up!
Old May 5, 2009 | 04:28 AM
gboezio's Avatar
Good work, I'd love to have access to a mill, I may buy my own in the future so I can make all those parts I can think of
Old May 6, 2009 | 09:26 PM
superdutyd's Avatar
Almost done, I just have to attach the adjuster nut. I think I will drill and use a drive pin to attach the nut. I'm not much of a welder. I think APE uses a pin to attach theirs too.
Old May 6, 2009 | 09:28 PM
superdutyd's Avatar
Almost forgot the pic.
Old May 6, 2009 | 09:32 PM
Truckinduc's Avatar
Not going to countersink the bolt heads? Makes adjusting them very easy.
Truckinduc's Avatar
like this
Old May 6, 2009 | 09:47 PM
superdutyd's Avatar
I was going to, but for some reason I wanted to use the stock bolts. Don't know why now. Now that I see it, I probably will c-bore them.
Old May 6, 2009 | 09:49 PM
Truckinduc's Avatar
mine use the stock bolts. You can thread the stock bolts in untill they bottom out to find out how deep you need to go.
Old May 6, 2009 | 09:53 PM
superdutyd's Avatar
Never thought of that. I'll have to try that.
marmaladedad
Aug 4, 2011 12:40 PM
CruxGNZ
Mar 12, 2011 01:45 PM
hazzy
Aug 26, 2007 07:50 PM
CNI Dawg
Dec 16, 2005 09:09 PM
divingindaytona
Mar 19, 2005 03:11 AM
