Loud pop, now no start
Old Aug 30, 2010 | 07:47 AM
thefitzvh's Avatar
thefitzvh is on a distinguished road
I attempted to start it this morning to go to work, and there was a loud pop (same kind i get occasionally with downshifting now that i have these aftermarket pipes on it)
Now, she cranks but won't fire. Behaving almost like it does when you try to start a bike with the cutoff switch engaged.
I have a voltmeter, just not sure what to check or what values to look for. I don't have a service manual yet.
Could it be the cutoff switch? if so, how do i check it?
Old Aug 30, 2010 | 07:52 AM
ima98chickenhawk's Avatar
ima98chickenhawk is on a distinguished road
i bypassed mine when it started giving me **** why not try that? now my bike works fine i just have to drop the stand while in gear or turn the key to shut off, neither one is any harder than hitting the kill switch.
Old Aug 30, 2010 | 07:56 AM
then again i had no "pop" so that might not be where you want to start. i would check fuses first. maybe your not getting spark. thats where i would start. the wire going to the coil from cylinder 2 is right by the battery mounted to the rear sub frame on the throttle side, use your voltmeter but i have no idea what values would work anything above nothing means move on IMO.
Old Aug 30, 2010 | 08:02 AM
thefitzvh's Avatar
ill check fuses first. bypass the switch second.
Fakk. My corvette isnt running right now either so this is killing me.
Old Aug 30, 2010 | 08:17 AM
Check the R/R and the main fuse... Both can make popping sounds when they fail...
Old Aug 30, 2010 | 09:26 AM
thefitzvh's Avatar
Forgot to mention.... lights/etc still work.
Would that rule out the main fuse?
Old Aug 30, 2010 | 10:06 AM
That it would... Doesn't rule out the R/R though...
Old Aug 30, 2010 | 10:09 AM
thefitzvh's Avatar
Hmmm. OK. I downloaded the FSM, i'll check 'er tomorrow morning. Anything else i should check while im in there? bike has just about 7000 miles
SuperHawkins
Apr 10, 2014 03:38 PM
Montana
Aug 7, 2010 07:12 PM
steve29
Apr 19, 2010 07:14 PM
nova_scotian_996
Jan 1, 2007 03:37 PM
ClevelandSuperhawkRumble
Mar 13, 2005 03:09 PM
