Ignition switch removal
Old Jun 8, 2013 | 04:42 PM
wtacoma's Avatar
wtacoma is on a distinguished road
Anyone have any tricks for removing the two shear bolts that hold the ignition switch in? I used torx bits to remove one from a CBR I had with no problem. Just tapped it into the bolt to make it snug.
But with the Hawk a 40T is too small and a 45T is too big.
Old Jun 8, 2013 | 07:39 PM
A few years ago I lost my key at the local outlet shopping center. It was never found. Had no trouble removing my ignition, then I took it to the local dealer with proof I owned the bike and they made a key in no time. Pretty sure it was just allen head bolts, I could be wrong though.
Old Jun 8, 2013 | 08:29 PM
thetophatflash's Avatar
Don't know of any Torx heads on a stock '99. They can be used if needed, to remove Allen heads.
Old Jun 9, 2013 | 02:53 AM
wtacoma's Avatar
The Hawk I have is an '05. Maybe they changed the bolts somewhere along the line, because they sure aren't allen heads.
Thanks
Old Jun 9, 2013 | 04:43 AM
Thanks
Can you snap a close up?
Old Jun 9, 2013 | 07:20 AM
On the newer bikes it's usually just a smooth ball with a litte rough metal in the centre, as it's a one-way, shear bolt... The best option for those is usually a dremel with a small cutting disc to make a slot for a screwdriver... Fiddly, but works...
Old Jun 9, 2013 | 11:02 AM
wtacoma's Avatar
Thanks Tweety, that's what I thought I would have to do. Just wanted to see if there was another way.
Thanks also to everyone else for responding!
inderocker
Apr 26, 2010 06:44 PM
fundgh
Jan 6, 2010 03:26 PM
FL02SupaHawk996
May 1, 2008 11:23 AM
TexasWino
Apr 14, 2008 12:54 PM
Hawkrider
Mar 5, 2008 05:33 PM
