Ignition control unit swap
Old May 13, 2009 | 02:54 PM
skidid's Avatar
skidid is on a distinguished road
I was wondering if anyone knew whether the 2001+ ICU could be used on the older hawks. I'm thinking a newer ICU would be better than using an ignition advance because it adjusts itself based on rpm as opposed to staying advanced like the rotor would do. Any thoughts on this would be appreciated. Thanks
Old May 13, 2009 | 03:19 PM
I am fairly sure they use the same ICU across all years. The dash changed, and with that one of the two temp sensors and a fuel level sensor replaced the reserve light sensor, but the actual ICU stayed the same. (from what I can tell)
Old May 13, 2009 | 04:25 PM
Well as far as I know there aren't any different between years... Don't know for sure though...
But I can tell you that running a newer one worked as normal on my 97 when a friend had problems and we where swapping things around to troubleshoot...
Old May 13, 2009 | 05:22 PM
skidid's Avatar
I know the part numbers are different. I've read that the ignition rotors don't do anything for the 2001+ bikes because the ignition already has a built in curve. I can't find where I read that now but I know it was in a discussion about the "Factory" ignition rotors. Was the ICU you swapped out a 2001+?
Old May 13, 2009 | 05:53 PM
JamieDaugherty's Avatar
Even the earlier models have a 3D ignition map. It varies the ignition advance with rpm as well as throttle position (that's the reason to keep your TPS adjusted correctly). Maybe there was some changes to the ignition mapping or something, but otherwise I kind of doubt you'd see any improvement by switching.
Old May 13, 2009 | 09:14 PM
There is a difference between the ICM's, at the very least a physical difference. There probably aren't any performance gains to be had though. I'm sure it has everything to do with emissions. Every 2001-up VTR that I've had my hands on (including my '05) pauses at 2k rpm before returning to idle whenever it has been revved. Don't know why, they just do.
Old May 14, 2009 | 12:50 PM
skidid's Avatar
Alright, forget it then. It would be cheaper to do the ignition advance anyway. I just was wondering if the ICU swap would be a better choice. Thanks for your help. Nice forum, I get on here whenever I need help with anything but have never needed to post because usually the question has already been answered in a previous thread. I guess that's a testament to how much info in on here. Thanks again.
jswisc
Jul 18, 2014 08:19 AM
motogomojo
Jul 14, 2011 06:48 AM
mdbuehler
Apr 22, 2009 03:03 PM
Ogre8472
Aug 31, 2007 01:06 PM
NovaWildcat08
Jun 25, 2006 05:04 PM
