If you have not replaced CCT- DO IT NOW!
Old Oct 23, 2008 | 10:14 AM
  #61
motojoe's Avatar
Sexual Daredevil
All is good. Test ride went well. Seems to have better off idle response. Photos of the new(to me) high mounts comming.
Old Oct 24, 2008 | 02:51 PM
  #62
Unclutchable's Avatar
Unclutchable is on a distinguished road
Originally Posted by 01SuperChicken
All the bikes I see with this problem seem to be 98 models.
Should start a thread/sticky with your model year and the mileage when your CCT failed.
I just hit 11k, so I'm not too worried about the issue...around 30k, if I still have my Hawk, I'll start getting nervous.
My birdy is an 02'. I changed my stockers for APE's at 18k miles because the front one was clacking. I see lots of post-98 hawks with this problem. Don't get too comfortable up in your seat just yet man
Old Oct 24, 2008 | 07:18 PM
  #63
Scooberhawk's Avatar
Señor Miembro, Ay Caramba
I figure I should tack on to this current thread instead of starting a new one...
While riding to work a couple days ago, I noticed a strange sound coming from below me. It reminded me of a flat tire - kind of a dull, rapid clacking. It seemed to only present itself when I would accelerate between 3 and 4k rpm. I could not detect it below or above that general range, and it would only do it while under load. I came home after work and revved the motor a bunch of times and couldn't reproduce it.
I noticed the claking within the first minute I was on the bike. I immediately started doing low speed swerves to see if my tires flat at all, but all felt okay. It had seemed like it could have been the chain and sprockets, but after a few downshifts, I decided it was rpm dependent, although I suppose that may not rule out chain and sprockets which have a tad over 10K mi on them.
I'm just wondering if it seems like this could be an impending CCT failure. Any thoughts? The bike is parked for now, but I'd like to be able to ride it soon without fear of bending a bunch of valves. Any input is much appreciated. Thanks in advance.
Old Oct 24, 2008 | 08:01 PM
  #64
You've been around here for a while Scoober so if you're looking at 16k to 18k on the clock it's time. This really is not to be fucked with or dally'd about. I saved my Superhawk but I crushed the valve train on my Prelude by not paying attention. It killed me. Such a fun little car.
It, absolutely, renders the vehicle to worthless or expensive/intensive repairs.
Old Oct 24, 2008 | 08:15 PM
  #65
In all honesty it could be carb slides, you can hear them mostly in the rpm range you described. I noticed my CCT noise most prominently after i had been riding a few minutes sitting at a stoplight, at or near idle. Was very easy to pick out.
That said, APE's are $50/ea. A little peace of mind and some preventative maintainence is all it will give you, but it's well worth it knowing that CCT failure is a real problem regardless if Honda will acknowledge it or not.
looking back, i wish i had gotten my friend's video camera/mic and stuff and made a short video. i've seen lots of questions on this forum from the lucky ones that were given some warning before failure "is this what they sound like?" dunno about anybody else but personally whenever I see a superhawk out in the wild and I can chat with the owner I usually head towards the CCT question.
Old Nov 1, 2008 | 09:52 AM
  #66
RK1's Avatar
RK1
Just finished installing and adjusting the A.P.E. CCTs on my '03. No more BB's in the beer can sound when I ease off the throttle. I feel better.
Did the rear cylinder with the cam cover off. Chain was pretty tight with adjuster finger tight. Figured it was OK to leave it that way (it was).
Did the front without removing cam cover. Thought finger tight good for rear equals finger tight good for front. Wrong. Fired it up and front clacked like all hell.
Ended up with the rear finger tight and the front finger tight plus 1.5 to 1.75 more turns in.
Anybody know why it would be different for each cylinder?
Old Nov 1, 2008 | 11:06 AM
  #67
Kendrick's Avatar
The Hypno-Toad
In regard to anyone thinking they may have a problem, just replace them. On mine it turns out I bent all four valves. I'm having a shop rebuild my heads for me. The exhaust valves are about $70 a piece and the intake more like $25. Either way when this is all said and done it will cost me probably $750, new gaskets, apes, top end rebuild; and that's with me doing most of the work. If you're worried about a noise don't ask us, just change out to manual CCTs and be done with it.
Old Nov 4, 2008 | 05:33 AM
  #68
BeerHunter's Avatar
Slacker
I must ask if you forgot to turn the engine before replacing the front CCT, or turned the engine the wrong way or perhaps to the wrong timing mark? I can think of no other reason, other than the possibility that the front CCT was already sloppy to begin with and you did this procedure before a catastrophic failure could occur.
Old Nov 4, 2008 | 06:13 AM
  #69
RK1's Avatar
RK1
I was careful to bring each cylinder's piston to tdc before replacing the ccts. I'm certain I did it right because the rattle is gone and the bike is running fantastic.
I would assume more wear up front since that's where the noise was coming from, so would explain maybe needing to turn the front manual cct in farther to REACH finger tight.
Still don't understand why front would require more tension PAST finger tight than the rear cylinder.
Old Nov 4, 2008 | 10:24 AM
  #70
Anyone ever replaced the cam chain thinking that it was near the end of its days and the CCT eventually wouldn't be able to adjust that far?
Old Nov 4, 2008 | 07:39 PM
  #71
Yes, I think Caffiene Racer replaced the chains at 30K. When he retired his Superhawk it had six fig's on it.
Old Nov 4, 2008 | 08:00 PM
  #72
Gregw's Avatar
What's a half dozen pieces of fruit got to do with cam chains?
Old Nov 4, 2008 | 08:49 PM
  #73
Old Nov 5, 2008 | 02:04 PM
  #74
I meant 160,000 miles.
Old Nov 5, 2008 | 05:56 PM
  #75
Gregw's Avatar
I figured, my evil side wouldn't let me pass it up though.
Old Nov 5, 2008 | 05:58 PM
  #76
JPP's Avatar
JPP
So is it me? I'm 50 this year and ready to buy a bike after 16 years w/o one. My last was a new '86 vf750 interceptor. Which gave me plenty of great rides up the winding Taconic State PKWY before it's transformation into an engagement ring. Big mistake. Now many years later I find myself looking for a ride again. My friends have Harleys. Not my style. I'm puttering around looking for dream bikes....Norton, Ducati, Guzzi. All crazy money. I See this Kawasaki '80's KZ1300 perfect condition naked thing at starbucks one day and say, "yeah maybe". I start reading about 'em at a related web site and I get scared off by the moderator screaming about the cct that WILL FAIL and turn the bike into an anchor. Then I see it. A VTR 1000. Let's see, V twin, "Poor man's Ducati", Dead sexy '98 with 4300 miles, $2500.00. What's the problem? I'm a proud owner. Boy do I love this bike! Now the CCT thing all over? What gives? When should I change 'em?
Old Nov 5, 2008 | 06:03 PM
  #77
SlowHAWK's Avatar
I'd recommend changing them when you do a valve check since everything is apart already, or since you mentioned the Taconic State parkway, I assume your in NY or CT.... which means in 1 month, you'll have plenty of time to do it when it's 25 degrees out there!!!
J.
Old Nov 5, 2008 | 07:35 PM
  #78
JPP's Avatar
JPP
Will do. You got that right. I was in Mt Vernon today.
Old Nov 7, 2008 | 07:44 AM
  #79
motojoe's Avatar
Sexual Daredevil
Glad to see so many people are replacing the CCTs. Nice to know that a good warning is preventing many catastrophes from happening. Hope everyone sleeps better at night now. I know I do. Lesson learned.
Old Nov 7, 2008 | 03:24 PM
  #80
LineArrayNut's Avatar
I could ride in
seems like post 10K miles previous 16K is the time to do it; anything more is a chance that is waiting to progress into a possibility that becomes a probability...
Old Nov 11, 2008 | 06:19 PM
  #81
Rock's Avatar
Rock is on a distinguished road
Put me on the list of " ordering tommorrow" my Hawk is closing in on 14 K
100 $$ and a little time is real cheap to me, thanks for the info..
sunshinehawk74
Jul 1, 2013 07:00 PM
WhOrD
Mar 21, 2013 10:44 AM
Tebs
Oct 4, 2012 12:09 PM
1down5up
Apr 3, 2011 02:35 AM
Ludicrous_Speed
Jan 20, 2010 09:01 PM
