Idle problem after rejet.... help please.
Old Apr 18, 2010 | 08:27 AM
j shizzy wizzy's Avatar
mildly retarded
Hey all,
I bought a set of Jardine RT-1's for a smoking deal and put them on then took the bike to Fey Meyers in Denver, for a re-jet. Well, I got the bike back yesterday and it runs great and sounds great!
Problem is, it runs great after its warmed up. When I start the bike cold now, It will barely hold its own idle until the temp. gauge reads 140. after that it purrs at 1k RPM. Soooo, I have to sit there and babysit the bike for awhile until it gets up to temp. by constantly blipping the throttle......this will get annoying soon.
Before the rejet and exhaust, I would simply pull the choke and let it idle for less than a minute, then push the choke back in, blip the throttle, and the bike would idle great!
So, is there an adjustment I can expect from the shop to fix this? or is this normal for my situation and I must live with it??
Thanks amigos!
Old Apr 18, 2010 | 08:41 AM
shizzy, Try upping the idle a few hundred rpm, to as high as 1400 or so. If you don't know, it's the black plastic **** accessible from the right side below the carbs. You can just get your fingers in there to adjust it.
Congrats on getting some nice sounding cans. When I get my bike back from repair (after being redlight rear ended) it'll have Yosh titanium slip-ons. By the way, don't toss those stock cans, they're $1100 a pair from Honda, as I found out.
Old Apr 18, 2010 | 08:58 AM
cliby's Avatar
Does the choke make it better when cold or no effect on it? Once warm what does it idle at?
Old Apr 18, 2010 | 09:02 AM
mildly retarded
the choke has an effect, but not enough to keep it from dying. once warm idle is around 1000 to 980.
Old Apr 18, 2010 | 09:04 AM
mildly retarded
thanks guys for the input. 1100 bucks from honda!!?? no one in there right mind would pay that...or would they? hmmm.
Old Apr 18, 2010 | 10:05 AM
cliby's Avatar
did they tell you the new setting when they rejetted? like main, pilot, needle position and AF screw settings? If it runs great everywhere else, then I would guess it might be the choke cable/s not inserted correctly or possible the AF screw. If you take off the air filter box you can check the choke circuits - just remove them be sure they are working right and then reinsert. and if they look like they are in right just pop off the carbs enough to back out the a/f screw 1/2 turn.
Old Apr 18, 2010 | 10:33 AM
+1
Old Apr 18, 2010 | 10:36 AM
mildly retarded
nope, they gave me no spec.s on where everything was set. I turned the idle up a bit and that seems better for now. I'll have to take it out again and get a feel for whats going on.
Old Apr 18, 2010 | 11:23 AM
storm_rider's Avatar
The shop should have only installed larger main jets for the exhaust retrofit.
I would ask them what they did exactly. Strange that idle has been affected as installing larger main jets should not have affected idling.
The shop should fix what they did. You didn't pay them to screw things up.
Old Apr 18, 2010 | 02:26 PM
Red_Liner740's Avatar
larger main jets have nothing to do with idle.
for one the idle is set too low...its supposed to be 1200 warmed up, mine will idle at 1300 warm and 1000 rpm cold
so if you bump the idle up higher it should help.
thedeatons
Jun 21, 2015 09:11 PM
Blueracer
Jun 4, 2010 07:36 PM
MLB
May 8, 2009 06:19 PM
trinity012
Jun 9, 2007 08:46 PM
DaxMiddler
Apr 28, 2006 03:22 AM
