I hurt my baby!
Old Mar 9, 2010 | 10:37 AM
Aramis's Avatar
Aramis is on a distinguished road
I hurt my baby!
This weekend while working in the garage I caused a crack in my fairing . What's the best and cheapest way to fix this.
Attached Thumbnails I hurt my baby!-img_0454.jpg   I hurt my baby!-img_0455.jpg
Old Mar 9, 2010 | 10:50 AM
Wicky's Avatar
First thing is to drill a small hole just beyond the extent of the crack to stop it going any further.
A search of the forums/google will bring up past threads/info on plastic welding, v in crack , sanding, blending in spray etc
Old Mar 9, 2010 | 10:56 AM
Take the fairing off and plastic weld from the back. (Use a low wattage soldering iron and zip ties for the cheap way)
Then if you are careful you might not need to repaint.
Old Mar 9, 2010 | 11:08 AM
I use this stuff for plastic repair and have had good results with it.
http://www.plastex.net/index.html
Old Mar 9, 2010 | 11:49 AM
Stevebis1's Avatar
I'v got a stress crack in almost the same place, but about 1/4 as bad - it never made it past the horizontal. To stop it from geting worse I took a piece of plastic (the plasic tie from a loaf of bread) put couple drops of epoxy and glued the plasic over the crack to hold it together. From the outside it is impossible to see the repair.
Old Mar 9, 2010 | 12:36 PM
cliby's Avatar
I know nothing about plastic repairs. I personally would change all the bodywork to yellow to remove the crack and improve the performance of the bike........
more seriously, when yuo guys say take a small piece of plastic or zip tie, are you just heating up the plastic and 'welding' it together? do you heat the plastic piece or the original bodywork at the same time?
Old Mar 9, 2010 | 12:55 PM
Low wattage soldering iron... Use it to melt both the piece of ABS plastic and the fairing piece... I basicly use the ziptie like a welding rod/soldering tin... Work it down a wee bit past the surface to get it to stick, but not to deep because then the front gets damaged and you need to repaint...
Old Mar 9, 2010 | 03:14 PM
toy4xchris's Avatar
toy4xchris is on a distinguished road
That is some good info I have been trying to figure out an easy cheap way to fix my fairing.
Old Mar 9, 2010 | 03:19 PM
mdbuehler's Avatar
mdbuehler
The zip tie trick works amazingly well. I've just fixed my tailpiece tabs, and using washers created whole new mounting tabs for my trashed CBR front fender. They are rock solid. Fixed the cracks in it too. I've even fixed several of the kids RC race cars when he's stuffed them really hard and broken one bit or another, neat trick!
Old Mar 9, 2010 | 04:20 PM
cliby's Avatar
thanks tweety and others. I will have to give this a try. and by low watt you meaning just one of the little hand held jobs like 10W or so? guessing lowest amount of heat to do the job
mdbuehler: I have some broken tabs on the RVF400 fairing panels that I picked up last year as well. Did you just use the washers and then plastic weld them into place?
Old Mar 9, 2010 | 05:15 PM
spladle160's Avatar
Methyl Ethyl Ketone. use a q-tip to get a little into the crack squeeze together for a few minutes. It's now chemically welded. you can also use abs glue or make your own by melting abs (shavings are best) into the MEK. Legos are abs and make wonderful reinforcement with a little home made abs glue to hold them in place.
Old Mar 10, 2010 | 01:25 AM
I think the old one I'm useing is a 15W or so, basic flat wedge tip... Just make sure you don't try to solder with it afterwards... Won't work very well...
Old Mar 10, 2010 | 05:59 AM
Indeed, 15W is probably perfect.. I have a 25W one I have been using and it is too hot so the resulting fix is brittle, even when I minimize the time in contact with the plastic.
10W might work, I don't know.
Old Mar 10, 2010 | 09:38 AM
YOUNGJESTER's Avatar
mad skill collector
YOUNGJESTER is on a distinguished road
Thumbs up
+3 ABS glue ,The crack you have is common, mine was cracked just like yours . do not drill the end of the crack!
Just sand the back of it to expose the abs and if to have a hugger on then use the plastic from the stock mud flap to cut a small square to span the crack with.
Old Mar 10, 2010 | 03:32 PM
mdbuehler's Avatar
mdbuehler
Lucky! I tried for a few years to get an RVF imported here, they would never let me though.
Yup, I used superglue to hold the washer in place, then literally went all around the thing, inside and out with molten zip tie to rebuild the entire thing, then dremmeled / sanded it to a more presentable shape.
My soldering iron is one of those butane(?) powered ones. Works very well, and once you get a feel for it you can do some fairly elaborate repairs.
Old Mar 11, 2010 | 05:15 AM
Aramis's Avatar
All,
Awesome tips. This will be my weekend project. Seems like an easy enough repair.
Thanks.
Old Mar 11, 2010 | 05:16 AM
Aramis's Avatar
Youngjester, why no drilling of a hole to stop the crack from getting bigger?
Old Mar 11, 2010 | 06:06 AM
Well, if you do the repair right you won't need to touch up the front and the crack will not spread since it will be repaired... And drilling a hole makes it kind of necessary to fill the hole and then sand and touch up the front...
A large crack in a high stress area where you don't have the option to repair it without messing up the front, then yes, you should drill it... Here I'd try to avoid it if possible...
Old Mar 11, 2010 | 06:07 AM
cliby's Avatar
[QUOTE=mdbuehler;257006]Lucky! I tried for a few years to get an RVF imported here, they would never let me though.
QUOTE]
I really did luck out on the RVF - someone had done all the dirty work about 2 years earlier, it was local and it was a good price. I mostly use it on track but its great that is licensed. it handles very well, and its a lower speed thrill which isn't all bad
Old Mar 11, 2010 | 08:14 AM
mad skill collector
Drilling the hole is a technique used in glass. I beleve that the crack was made by stress when moving the bike, not from vibration . Drilling will not help in this situation. It is also cosmetically bad.
We have a shop here in Hayward "Cycle Salvage" , the owner Chris is a magician at plastic welding , I took my plastic to him and he repaired it good as new for a reasonable price.
Old Mar 11, 2010 | 09:41 AM
mdbuehler's Avatar
mdbuehler
Nice. I was even talking to some VERY dodgy importers towards the end lol Got all the way up the phone tree to whomever in DC was in charge of all things with wheels coming in on boats and he wouldn't budge. They occassionally pop up locally, but the markup is extreme! My little Bandit 400 was one of my all time favorite bikes, its fun to be able to put a bike through its paces without fear of prison time. Too much WOT on the Hawk is guaranteed trouble
RWhisen
Apr 17, 2013 04:28 PM
Chuey
Jun 20, 2007 05:17 PM
BMiller
Mar 27, 2007 08:17 PM
superhawk22
May 24, 2006 09:56 PM
EngineNoO9
Apr 24, 2006 12:46 PM
