How many bottles of fork oil to buy?
Old Jan 9, 2016 | 03:00 PM
thedeatons's Avatar
My local Honda shop says the superhawk should hold about 450cc's of oil per leg, which equates to 900cc's for both legs. This translates to about 30oz for both legs.
1 liter of fork oil is 33oz.
Using this math I should only need one bottle of fork oil to do a complete fill for both legs, (assuming dry fork legs). Do you guys agree with this, or should I order two bottles? I will be completely cleaning out the forks, drying everything out, then installing fresh oil.
James
Old Jan 9, 2016 | 06:07 PM
thetophatflash's Avatar
One would suffice given the quantity needed.
Old Jan 9, 2016 | 06:46 PM
If your going to OEM levels one, if your going to a higher(more fluid) you'll need two
Old Jan 10, 2016 | 06:18 AM
thedeatons's Avatar
Good point... I don't remember what oem air gap was, but i'm going to a 140mm air gap.
So how does that change things?
James
Old Jan 10, 2016 | 08:23 AM
James
Id have to look up what Jamie told me to set it to.. I just remember I use a bottle and a bit to change seals.
Old Jan 10, 2016 | 09:29 AM
thedeatons's Avatar
I'll just order two bottles... I'm pretty set on running a 140mm air gap, so i figure it'll be better to have some leftover fluid.
James
Old Jan 10, 2016 | 11:12 AM
James
Thats a good bet to not get caught short..... Sorry cant help... I keep so much oil on hand,,, I don't really order for a job, just stock unless it's something I don't have already.
jamie had suggested a oil viscosity of 15-19cSt for my forks (his valves and shim stacks)I chose one at 16.2cST@40deg, Maxima Racing fork oil 5wt.
Next time I drain, clean and refill I may try something in the higher end.
Im told 7.5wt Ohlins is 19cst@40deg
Old Jan 10, 2016 | 01:15 PM
thedeatons's Avatar
I'm going to use Silkolene PRO RSF 7.5. Roger seems to like that one, as do many others on the net.
James
Old Jan 10, 2016 | 01:28 PM
James
Unconfirmed but what I have in my notes
Silkolene Pro RSF (7.5wt)
37.00 cSt @ 40c
12.00 cSt @ 100c
Old Jan 10, 2016 | 01:30 PM
thedeatons's Avatar
I'm using stock valving and Roger's fork mod.
James
Old Jan 10, 2016 | 09:56 PM
Cadbury64's Avatar
VTR virgin
One litre is plenty even with higher than stock oil levels.
Old Jan 11, 2016 | 06:36 PM
superbeater's Avatar
I don't know if this is a good idea or not, but I usually flush my forks with some paint thinner during an oil change to flush out any sludge, metals, etc. After dumping out the thinner I put some new fork oil in, pump the forks several times and then dump it out before final refilling. Sooo I need a little extra oil.
Old Jan 11, 2016 | 06:39 PM
thedeatons's Avatar
Yes, that is a good idea. I did something similar today.
I rinsed out with QD Contact Cleaner, also filling the cartridge with QD and pumping it out, finally airing everything out with compressed air. I rinsed at least three times...
Good input, thank you!
James
Old Jan 14, 2016 | 04:21 AM
James
I dump and flush a couple of times with inexpensive ATF, pump dry and invert drain overnight if time permits.
I fill with Silkolene pro rsf 5 wt to 150 mm air gap but I may be high there as I did not check my records and its been 2 years as it's on my winter todo list. My valving and damping is by Greg Nemish. I made my own preload spacers and run RT .90 or .85 springs (again brain fade) but I like it a little soft as it balances well with my Penske shocks spring and damping.
carib919
Dec 20, 2011 01:52 PM
BDR1783
Nov 6, 2010 07:40 AM
AngryOlaf
May 25, 2010 09:39 AM
ericjansen
Jul 29, 2007 08:07 PM
dabimf
Jan 22, 2005 07:21 PM
