how do turn the crank?
Old Apr 28, 2007 | 04:22 PM
calitoz's Avatar
Escape Reality
Hey guys
I am about to embark on the changing of the CCTs myself and have the hawk on rear stand. The question is how do I get to the index mark "FT" and "RT" for TDC? I tired to turn the wheel in 1st gear but it won't budge. How do I turn the crank to align the marks at the timing hole?
Thanks
Old Apr 28, 2007 | 04:36 PM
SlowHAWK's Avatar
Use a socket and a long breaker bar.... you'll need to remove the cap/cover with the hex on it on the left side case cover.. under that you'll be able to access it.
BTW... you might wanna try rotating the wheel at a higher gear 6th... I believe this will give you more mechanical advantage...
J.
Old Apr 28, 2007 | 05:05 PM
That's right. Use high gear, make sure the plugs are out - little movement of the back tire will get you there.
Old Apr 28, 2007 | 05:18 PM
calitoz's Avatar
Escape Reality
Thanks...6th gear seem to work..right now is too dark but first thing in the morning, I will attack it..Thanks guys..
johnclopp85
May 13, 2009 07:20 AM
Motohead
Aug 20, 2006 01:06 PM
KC_Rider
Feb 4, 2006 05:59 PM
inderocker
Jul 7, 2005 08:04 AM
