how do turn the crank?
Hey guys
I am about to embark on the changing of the CCTs myself and have the hawk on rear stand. The question is how do I get to the index mark "FT" and "RT" for TDC? I tired to turn the wheel in 1st gear but it won't budge. How do I turn the crank to align the marks at the timing hole? Thanks |
Use a socket and a long breaker bar.... you'll need to remove the cap/cover with the hex on it on the left side case cover.. under that you'll be able to access it.
BTW... you might wanna try rotating the wheel at a higher gear 6th... I believe this will give you more mechanical advantage... J. |
That's right. Use high gear, make sure the plugs are out - little movement of the back tire will get you there.
Thanks...6th gear seem to work..right now is too dark but first thing in the morning, I will attack it..Thanks guys..
