Hot regulator/rectifier
Old Apr 23, 2007 | 08:43 PM
wardo996's Avatar
wardo996 is on a distinguished road
How hot should the R/R get? Sometimes when I run the bike the R/R gets pretty hot. how hot is normal? THANKS!
Old Apr 23, 2007 | 08:50 PM
I've never felt mine, but I'd think they get pretty hot. Besides regulating voltage to the battery and the rest of the electrical system they also dispose of unused generated power. This, of course, is done by generating heat. It's actually better for a R/R when you use a more power (extra lights, heated gear, etc.) because it runs cooler.
Old Apr 23, 2007 | 09:08 PM
wardo996's Avatar
Thanks Hawk! That makes me feel a little better! You're the man!
Old Apr 24, 2007 | 01:01 AM
johnnyhonda's Avatar
johnnyhonda is on a distinguished road
There you go brah another satisfied costumer.
Old Apr 24, 2007 | 10:08 AM
Blurr's Avatar
Blurr is on a distinguished road
I replaced mine iwht a tourmaster, and it still gets quite warm but it does have fins
Old Apr 24, 2007 | 07:23 PM
V = I * R
Voltage equals current times resistance. Resistance does not change. Thus, if current increases so does voltage, and vice versa.
A generator creates electricity because a current-carrying conductor in a magnetic field with relative motion between the two creates movement of electrons. The faster the relative motion or the stronger the magnetic field then the more electricity (current) is generated. This is why the voltage at idle is lower than at 5000rpm. Additionally, the generator generates 3 phase AC power. So to convert that to DC the R/R uses a series of diodes to rectify it to DC so it can be used.
As I said before, the regulator part just "bleeds" off the excess current to create heat.
If in doubt, do a search. I'll start you out here: http://faq.f650.com/FAQs/VoltageRectifierFAQ.htm
Old Apr 24, 2007 | 08:45 PM
trinc's Avatar
V = I * R
i think i'll fall on my 20+ yrs in the electronic field. albiet not in the '3 phase generator' field.
heat is generated by current. period.
there are two ways to generate heat in a regulator. add load to the output & increase the voltage difference between the input & output.
if the input voltage increases and the output voltage must stay the same ( regulator ) adding more load to regulator only adds to the problem.
tim
Old Apr 24, 2007 | 09:13 PM
Tim,
I'm not asking you to go against what you've learned in the last 20+ years, I'm asking you to ADD to the wealth of electrical knowledge that you already have. Look, motorcycle charging systems haven't changed much in the last 30-40 years. I don't think that this "technology" was even taught when you went to school. I'm in the Navy and naval electrical systems are OLD TECH. They have to be. Works fine, lasts long time. And they have to be sailor-proof. Voltage regulators in the Navy aren't even this archaic. It's a waste of energy. BUT, this is essentially a PMG (permanent magnet generator) and thus there is no way to vary the magnetic field as you would in a more modern generator, so you have to do something with the current/voltage that is generated. You can't send it to the battery because it doesn't like to be overcharged. A float charge is just fine, thank you. So the voltage/current is removed by generating heat. Even Electrex, the folks who make the aftermarket R/Rs, say it dissipates heat: "Electrex USA’s technical genius is built into it’s line of regulator rectifiers. Electrex USA “RR” innovations are designed to stop overcharging and dissipate extra voltage
quickly."
Think of this kind of regulator as a relief valve, wastegate, or flood gate for DC voltage.
Old Apr 24, 2007 | 09:31 PM
trinc's Avatar
well that' s interesting. i will have to go read more about the motorcycle charging systems ( would never say i know everything ).
i started my training in the USAF so i'm not suprised you navy guys have a different electrical system than the rest of us.
tim
Old Apr 24, 2007 | 09:32 PM
Yeah, things were floating LONG before they were flying.
There are also many, many more planes in the ocean than there are ships in the sky.
Old Apr 24, 2007 | 09:53 PM
trinc's Avatar
this is interesting
http://www.electrosport.com/electros..._charging.html
yes, lots of boats. we were walking before that though. lets go find a marine & ask him.
tim
Old Apr 25, 2007 | 05:48 PM
Yeah! Great stuff, eh? I do wish they'd get the field controlled generator technology to the point where they are simple and reliable enough for motorcycle use. If they are, then why are Honda not using them? This is the type we use in Naval electrical systems, though a bit more complicated. It only makes sense to vary the magnetic flux to achieve the desired voltage, yes?
Old Apr 25, 2007 | 06:02 PM
PJay's Avatar
PJay is on a distinguished road
Hahahahahahahaha - I first heard this from my dad when I was a small kid - he was a WWII Britsih naval flier, on the North Atlantic convoys, where they had far more casualties from men falling into the sea than being shot down.
Old Apr 26, 2007 | 08:43 AM
SH1000MA's Avatar
SH1000MA is on a distinguished road
I just changed my R/R with an aftermarket one with cooling fins. My stock one is toast and took the battery out with it.
Montana
Oct 9, 2012 05:40 PM
wsharpman
Jul 4, 2012 02:31 AM
johnnyhonda
Jul 26, 2010 01:53 AM
Vega (streetfighter)
Sep 4, 2008 11:54 PM
Mark Carmody
Jul 28, 2008 03:43 PM
