help with rough running vtr
Old Jan 20, 2012 | 01:34 PM
thumperslaw's Avatar
thumperslaw is on a distinguished road
Evening guy's
Got my storm back on the road the other day after new motor been stuck in it and every thing seems fine....until you ride it.
If I hold it about 4-5rpm it stutters thru the rev range in all gears. I have stripped the carbs more then once today and checked coil packs plus plugs.
Using 190 jets with two turns on the pilot screws. Needle hight is on number.
Pulling the coke on don't help still does it.. like trying to ride a bull
So far i have re-jetted again and still no joy
Done
Full compression test
Leak down test
Checked fuel lines
changed exhaust
changed carbs
cleaned carbs
checked coil packs
checked spark plugs
Done cam timing
removed alarm
new emulsion tubes
And...........Still not got to the bottom of it all!
Aghhhhh
Any idea?
Old Jan 20, 2012 | 01:46 PM
thetophatflash's Avatar
What's the history of the fuel used?
Old Jan 20, 2012 | 01:54 PM
jay956's Avatar
My bike was extremely rich with a 185 jet, causing stumbling issues like you describe. Could it be your jetting is just way off? Also are your hoses connected to the petcock correctly?
Old Jan 20, 2012 | 02:02 PM
Fuel i use is 98 ron super unleaded stuff
All hoses are fitted right with no leaks and i took the fuel tap apart and checked that. All seems fine there!
I have only got a mild tuning work done which is
Full arka system with 280mm mtc pipes,k&n,stage one dyno jet kit.
Have tryed 190 jets,180 jets Still no help and 170 jets really mess the bike up to the point where is will not run at all.
What i am trying to find out is on the carb the hole that the needel slides in to (mine is ovel shape) but i cant seem to find that spare any where
Old Jan 20, 2012 | 03:59 PM
rz_racer_69's Avatar
Old and dangerous
Knowing nothing about it, but replaying what I have read here time and again, ditch the K&N, go back to OEM filter and OEM jetting, needles included. Keep the pipe, and follow the jetting correction instructions elsewhere here for replacing the pilot, raising the needle, and filling the front lift hole in the slide. More than once, that has "fixed" a jetting or running problem.
Old Jan 20, 2012 | 04:24 PM
I have thought about few times. So far am on my 3rd engine and not once have I had this problem! Until now ( its never been right from the start)
Keep spending money and getting know where
Old Jan 20, 2012 | 04:37 PM
You slides are trashed...... and as it sounds like you have a dynojet kit in there make sure you add the extra lift hole if you swap slides around.
Old Jan 21, 2012 | 01:10 AM
I think i might try that next. What's the chances of the needles been worn out?
I did get a low mileage set of carb's and they don't seem to fix the issue
Little update this morning, When riding it now (with 180 jets) needle on the 4th clip
it seems to be popping and banging when you let of the throttle
Old Jan 21, 2012 | 03:00 AM
Wicky's Avatar
Air leak at exhaust gasket / carb inlet? Did you use new Honda OEM collapsable copper gaskets when mounting the exhaust headers? (take out any remaining old ones from the new 2nd hand engine that can appear merged into the cylinder head outlet with camouflaging soot etc) Check condition of rubber carb inlets, if perished/cracked replace.
Old Jan 21, 2012 | 05:16 AM
Done new exhaust gaskets when i fitted the system on (i did clean around the port to)
I did a leak test (snap on tooling) and it's not showing any leak's any where
Old Jan 21, 2012 | 08:26 AM
I was more interested in how old and or possibly contaminated the fuel might be than the octane etc.
Old Jan 21, 2012 | 08:43 AM
My fault miss understanding there.
Fresh fuel and clean tank.
teh1034
Jan 27, 2013 10:26 AM
geekonamotorcycle
Mar 8, 2011 11:01 AM
Herbert
Jun 10, 2007 01:09 AM
Babelfish
Jun 8, 2007 03:50 PM
spdrcr
May 18, 2007 05:43 AM
