Rough Running Isues
Old May 15, 2007 | 09:47 AM
spdrcr's Avatar
spdrcr is on a distinguished road
Rough Running Isues
Help
My '98 Hawk pops at idle, backfires through the carbs at steady low RPMs and tries to die at stoplights. I bought the Hawk with 31000 miles and no service records. It has fresh gas. I performed a bafflectomy last week other than that I think it is stock. Where should I start.
Old May 15, 2007 | 11:02 AM
cliby's Avatar
how long have you had it? was it stored recently and when was it last running great? If its new to you and you have no idea you could start with routine maintenance items including checking plugs, cables, carb synch and adjusting the fuel mixture settings if you are sure the carbs are clean.
Old May 15, 2007 | 11:36 AM
Speed_Demon's Avatar
Vacuum leak, probably an unseated carb.
Old May 15, 2007 | 12:52 PM
spdrcr's Avatar
Thanks. I plan on pulling the tank tonight and checking all that stuff out.
Old May 15, 2007 | 01:06 PM
The lazy approach to this problem is to spray wd-40 around the carb boots/manifolds. If the rpm fluctuates that means its sucking it in.
Old May 15, 2007 | 07:50 PM
gboezio's Avatar
+1 on the vacuum leak, you can try a propane torch(unlit) it keeps the mess to a minimum.
Old May 16, 2007 | 05:45 AM
spdrcr's Avatar
Heres what I found so far. The spark plugs are NGK DR8ES-L. The air funnels (velocity stacks?) were reversed. Someone has been in there before and didn't use the right size phillips or was a muscle head on the screws. Tonight I will pull the carbs and see how they look. Thanks for the advice on the vacuum leak, I will check that when I put it back together.
Thanks,
Matt
Old May 16, 2007 | 06:07 AM
gboezio's Avatar
Check the jets for cleanliness, set idle screws to 2.5 turns check the mains and pilot jets size, check if the needles are adjustable, if so use the 3 rd notch from the needle body, use a cover screw to pull the needle assembly off the slide.
Good luck
Old May 17, 2007 | 12:42 AM
Those plugs are the wrong ones. Stock is NGK DPR9EIX-9. From dealer they are about $10 each. Probably half that if you order them from your local auto parts store and wait a day.
Old May 17, 2007 | 06:23 AM
spdrcr's Avatar
Last night I opened the carbs to see what the previous owner had screwed up in there . The jets were 178 front, 175 rear. Isn't that backwards? At least they were clean. Where does the vacuum line connect to the petcock, bottom or rear? I put it on the rear. I got it back together last night and started it. Sounded much better for the short time I let it run.
Old May 17, 2007 | 06:35 AM
gboezio's Avatar
Yep these are stock jets but backwards, bigger jet goes to the rear. What mods you have on the bike, exhaust and air filter ??
Old May 17, 2007 | 07:05 AM
Sounds like the previous owner was a pi** poor backyard mechanic....
Old May 17, 2007 | 07:42 AM
spdrcr's Avatar
The exhaust is stock with a bafflectomy. Stock air filter.
Old May 17, 2007 | 07:46 AM
spdrcr's Avatar
If you think that is bad you should see some of the other "repairs". Is there a comedy section of this forum for me to post the pics in?
Old May 17, 2007 | 09:56 AM
spdrcr's Avatar
Another thing I found was what appeared to be a synthetic cotton ball like material in the end of the front coolant line to the carb. I removed it before reassembly.
Old May 17, 2007 | 10:02 AM
brownrxmd's Avatar
brownrxmd
petcock vacuum
Make sure you put the vacuum line to the back of the petcock where the tube points to the left not the to the one pointing straight down, the one pointing down that was a 750 dollar lesson for me.
Old May 18, 2007 | 05:43 AM
spdrcr's Avatar
Smile
Wow! I thought it quick before.....now it screams. Just got the correct plugs, so they will go in this weekend. Now I can work on the other "repairs" that were made by the previous owner(s). I will post pictures of theses "repairs" in another thread.
geekonamotorcycle
Mar 8, 2011 11:01 AM
Denverhawk
Feb 20, 2009 07:24 AM
Motohead
Feb 23, 2008 09:42 AM
Herbert
Jun 10, 2007 01:09 AM
Babelfish
Jun 8, 2007 03:50 PM
