running rough
Old Jun 9, 2007 | 08:22 PM
Herbert's Avatar
Herbert is on a distinguished road
Question running rough
I'm riding an '05 VTR, recently fitted with Staintune slip-ons and K&N high-flow air filter. Definately made a big difference to power, especially with the baffles removed from the cans.
Problem is bike can't seem to hold a tune... I've had it since new, and every service it's had it runs really well, nice smooth power, starts easily for a couple of weeks and then just starts to get rough. After fitting the pipes/filter had it serviced/tuned, and ran beautifully for about a couple of weeks before back to old tricks but more pronounced this time.
Usually starts first time with choke on, now requires complicated choreography of clutch, throttle and start button and backfires at least twice before starting.
Main problem though is running rough at low/mid revs (3-4k) and with throttle steady. It lurches along, with revs moving +- 500 without touching the throttle. At idle it's fine, although will often stop dead with no warning. It's done this a couple of times whilst cruising along too. Under acceleration it's better, although down on power and seems to be really straining rather than opening up like it used to.
Otherwise I really rate the VTR - I ride it every day and any weekend I get the opportunity, with a couple of good long runs every few months (Phillip Island in March and September!). About to do my first track day in 6 weeks time, and love to have this solved by then.
I'm thinking about a carb kit to improve fueling to match the filter/pipes. Is this likely to solve the problem? I've read plenty about Dynojet products - are these the best to try, or are there others?
Thanks in advance.
Old Jun 10, 2007 | 12:07 AM
trinity012's Avatar
Hi Herb, IMO i think you gona need rejet your carb and sync them, I dont think SH work well w/o aftermarket a/f alone. I have Factory Pro jet (i got rob from local shop for $130 which U can get it for much less, on line) and replacement OEM 4 aftermarket a/f $30 work well even though i still have to re-adjust my jetting to perfection it but no time, too lazy to tear them up again. i run 180f/182r, pilot 50, 3rd clip, 2.5 turn fuel screw. hope this will help. 103 ponies-65 fb.
Old Jun 10, 2007 | 01:09 AM
Herbert's Avatar
Trinity012 - thanks for advice, looks like a carb kit is the way to go.
geekonamotorcycle
Mar 8, 2011 11:01 AM
Denverhawk
Feb 20, 2009 07:24 AM
Motohead
Feb 23, 2008 09:42 AM
Babelfish
Jun 8, 2007 03:50 PM
spdrcr
May 18, 2007 05:43 AM
