help with my clutch
Old Mar 27, 2006 | 08:59 AM
macworld's Avatar
macworld
help with my clutch
so i changed out the front sprocket from a 16 to a 15, got the chain readjusted, and put everything back together. pulled in on the clutch, nothing. now i know that the hydrolic line runs down to the front sprocket cover, so when i took that off, i messed something up. i have never had a hydro clutch before. my tl has a cable. what do i need to do here. does it need to be bled, if so what is the process for doing that? any help is greatly appreciated. thanks
Old Mar 27, 2006 | 09:05 AM
AZZKIKER's Avatar
You need to bleed your clutch especially if the color of the fluid is black. download the service manual from the internet (google it) and go from there.
Old Mar 27, 2006 | 09:07 AM
AZZKIKER's Avatar
the clutch slave cylinder has a nipple on it to bleed it. If you ever bled the brakes, same procedure for the clutch. You might need a second hand so one can pump the cltch and the other to bleed the nipple as pressure builds.
Old Mar 27, 2006 | 09:11 AM
macworld's Avatar
macworld
Re: help with my clutch
i guess i am not a good egooglelizer, cause i can not find anything like that (service manuel) on the net. does anyone have one that they can email me, or point me in the direction of one? thanks.
Old Mar 27, 2006 | 09:14 AM
superhawk22's Avatar
Do a search on here I think there are 2 links for sm's.
Old Mar 27, 2006 | 09:16 AM
Go here.
https://www.superhawkforum.com/viewtopic.php?t=1661
Old Mar 27, 2006 | 09:54 AM
Loco's Avatar
Loco
This happens to me just about every time I pull off that sprocket cover. Silly Honda put their clutch actuator right in the middle of the sprocket cover. AZZKIKER is right, you may need to bleed your clutch now, because the piston inevitably moved when you pulled off the clutch mount. On the part that bolts to the sprocket cover there is a rubber nipple, which you remove when you bleed the system of air. Just get some plastic tubing, and bleed it the same way you would your brake lines and your clutch will be back to it's usual self.
rafbo
Jul 16, 2011 10:24 AM
dannyz
Jul 19, 2010 07:21 AM
patience
Motorcycle News
Apr 13, 2010 10:31 AM
acarp
Sep 20, 2009 11:14 PM
mattvdsande
Mar 16, 2009 11:12 AM
