Help! Lurching and dying above 5K RPM
Old May 24, 2009 | 03:18 PM
DavidEW's Avatar
DavidEW is on a distinguished road
Just replace my R/R and battery and installed an HID kit. Took it out for a ride and noticed around 4500-5K it started lurching and when I gassed it it would die. What could cause this? Bike was in great shape and running fine beforehand.
Old May 24, 2009 | 03:22 PM
Did you take the tank off?
Old May 26, 2009 | 05:56 AM
nath981's Avatar
I noticed that there is no mention of TPS adjustment in you signature/mod description. Mine's a 98 also and this made a huge difference when it started to act up spontaneously one day. They're typically out of adjustment.
Old May 26, 2009 | 08:34 AM
LineArrayNut's Avatar
I could ride in
search term "PVLIR"
see if this has any bearing on your problem
Old May 26, 2009 | 07:56 PM
DavidEW's Avatar
Found it. Cracked vacuum hose and carbs out of sync. But good to know about PVLIR.
Old May 26, 2009 | 08:17 PM
nath981's Avatar
good you got things sorted out. what did you use to sync the carbs? I can understand the vacuum hose causing your condition, but not the carb sync. Next time you're under the tank, look at the TPS to see if it still has the original rivets, or if it been moved because if it hasn't, it could likely be out of spec as they usually are.
Old May 26, 2009 | 08:54 PM
Circuit_Burner's Avatar
guru of things sparky
If you dont have the proper guages, you can substitute with two small kittens.
Stuff them butt first into the venturis, and observe how deep their eyeballs recede when reving up motor.
Old May 27, 2009 | 04:06 AM
nath981's Avatar
sounds like something they might do in texas, just for the fun of it.
Old May 27, 2009 | 11:27 AM
DavidEW's Avatar
Tried the kitten thing but it ended really badly.
When the bike cut off I was on my way to work and was literally passing by my honda dealer and was able to coast and push in and drop it off and go to work. They were the ones who found the leak and adjusted the carbs. They also managed to drop my bike and break the custom painted mirror. I love dealers.
Old May 27, 2009 | 02:23 PM
nath981's Avatar
well then, that xplains the carb sync. sucks when you get one thing fixed and break another, huh? costly lesson.
kennywiz
Jun 11, 2012 05:58 AM
t-dogg
Dec 27, 2011 04:33 PM
evines
Sep 21, 2010 08:23 PM
pwshadow
Jul 25, 2010 09:15 AM
joshuatest
Oct 27, 2008 04:44 PM
