coolant refill amount?
Old May 26, 2009 | 01:00 PM
dshakes's Avatar
dshakes is on a distinguished road
sure this has been beat up worse than rocky balboa but how much coolant should i put in after a full drain? And to flush do i just run water through the radiator? Thanks fellas.
Old May 26, 2009 | 02:47 PM
It takes just under 4 quarts (1 gal) including the recovery tank. I used Honda HP premixed coolant which comes in quarts at 5 bucks per.
It wouldn't hurt to run water through, but I just drain and fill (my old coolant was clean though). Do not use any chemical flush. Have fun.
Old May 27, 2009 | 09:12 AM
RickB's Avatar
Just changed mine while doing the manual CCT conversion monday and it was 96 ounces or 3 quarts including the overflow tank.
Old May 27, 2009 | 05:02 PM
dshakes's Avatar
I drained it out of the bleeder bolt on the front cylinder but like a dummy forgot to drain the overflow. Took about a half gallon to fill up to the top of the rad. Ran it for about five minutes and will check to see if shes still topped off.
Christian_man30
Jun 3, 2010 07:55 PM
j_frank
Apr 28, 2007 11:40 PM
xecutech
Apr 9, 2007 08:53 PM
EngineNoO9
Oct 20, 2006 09:01 PM
faz
Jul 29, 2004 10:58 AM
