Help, fuel line question...
Old Apr 22, 2012 | 09:33 AM
raceruss2003's Avatar
raceruss2003 is on a distinguished road
This "should" be easy.
The bike was running great...Took bike apart a couple weeks ago to paint the tank and plastics. Disconnected the blinkers and fuel lines with fuel level switch. Basically the minimum to get the plastics painted.
Got painted, put plastics back on, reconnected blinkers, all fuel lines and fuel level switch connector, and now bike is running like poo. Will idle just fine, however when I give it a little gas the engine will start to miss and cut out if continue to give it more gas.
Anyone have any idea of what is going on? Been racing dirtbikes for years (30) taking them apart and putting them back together. Never had a problem like this...
Old Apr 22, 2012 | 09:42 AM
maniac2313's Avatar
maniac2313 is on a distinguished road
you hooked the petcock up wrong search and you will find the right way...
Old Apr 23, 2012 | 08:52 AM
aja's Avatar
aja
What they said. However your under tank hoses should be:
Vent and overflow tube on riders right side of tank on nipples.
Large fuel lines on petcock obviously.
Small vaccuum hose on riders left aide hooked up to the nipple towards the rear of the bike, it is a horizontal fitting.
Old Apr 23, 2012 | 10:35 AM
CrankenFine's Avatar
https://www.superhawkforum.com/forum...e-again-11643/
PVLIR acronym explainer for newer folks.
Old Apr 23, 2012 | 08:01 PM
Thanks for your help all. I went out and checked the vent lines. I believe they are in the correct order as stated above. Took them off and reinstalled and the bike is running better now. Very picky these bikes are...LOL
Old Apr 23, 2012 | 10:02 PM
Picky? Like hook up a fuel and vacuum line to where they go?
What did you use to do this job, a hammer?
Old Apr 24, 2012 | 03:58 AM
RWhisen's Avatar
Former Superchicken Owner
Yeah .... OK. You aren't the first one to do PVLIR, and you won't be the last.
Old Apr 24, 2012 | 06:17 AM
Hey raceruss, you are now obligated to respond to the next 10-20 posts asking this exact question.
Old Apr 24, 2012 | 07:35 AM
maniac2313's Avatar
Thats awesome itll only take like a month...
ProfChaos
Oct 4, 2012 09:14 AM
masterhacker1989
Apr 4, 2012 03:51 PM
mikstr
Mar 9, 2010 07:03 PM
hondavtr1000sp2
Mar 3, 2010 08:36 PM
lazn
Mar 26, 2009 08:37 AM
