exauste ???
Old Apr 23, 2012 | 11:36 PM
mileyguard's Avatar
mileyguard is on a distinguished road
exauste ???
ok i have the saintune high mounts on my bike a friend of mine noticed that the chain that runs threw the pipe is rubbing on the pipe is there suppose to be a guard on that or is my chain just not set ?
Old Apr 23, 2012 | 11:40 PM
saige's Avatar
the boss
if the chain is touching or riding on the pipe,either it is stretched,too many links or the wheel needs to be set back and aligned.
chain length is 102 links.make sure if you set the wheel back,it is aligned properly.
Old Apr 23, 2012 | 11:49 PM
mileyguard's Avatar
so theres no guard there?
Old Apr 23, 2012 | 11:54 PM
saige's Avatar
the boss
no,not on the pipe itself,just around the swingarm near and behind the sprocket cover.
Old Apr 24, 2012 | 03:14 AM
CrankenFine's Avatar
Old Apr 24, 2012 | 06:46 PM
mileyguard's Avatar
went and had the chain tightend when i was at the part shop it fixed my problem thanks for the info
Old Apr 24, 2012 | 07:38 PM
RWhisen's Avatar
Former Superchicken Owner
You ride a motorcycle and you don't know that the chain needs to be tightened from time to time? When was the last time you put lube on it or checked the condition of the sprockets?
Old Apr 24, 2012 | 08:34 PM
or that pesky, check the tire pressure....
Old Apr 24, 2012 | 09:44 PM
Haha, the what? I thought the only maintenance was to put fuel in it!
