Gauge Cluster dying.
Old May 11, 2007 | 07:56 PM
MarineHawk's Avatar
So I decided that in my last few days in the US, I'd install a new set of turn signals (Watsen Design, outstanding quality btw) and tool around northern WA. What happened was that about an hour into the ride, my speedo/tach/digital display all died. As in, the first two the needle dropped to 0 and the digital display only showed the clock. Pulled over, opened the fuse box and found a blown fuse. No biggie, replaced it and took off again. About ... 10 minutes? Maybe even 5 minutes later, the same thing happened, and it was the same problem, blown fuse.
I've never had any sort of electrical problems before and I splice wire fairly often and know the fresh bit of splice isn't grounding. But considering the turn signals continue working, as well as the turn signal and hibeam displays, I wouldn't think it was that anyhow. The neutral light died out too though, with everything else. I know this is rather a gaggle!@#$ of information, but are there any ideas of what it might be before I spend a few hours with my wiring diagram?
Old May 11, 2007 | 08:14 PM
The 12V wire for the turn signals is fused though the Meter/Tail/Illum fuse. This is where the source of your problem lies.
Old May 11, 2007 | 08:19 PM
MarineHawk's Avatar
Alright, that's what I've been slowly pieceing together as I browse through everything, good to get the reassurance.
Old May 11, 2007 | 08:50 PM
I have a pic of the wiring diagram in my Member's Pics on the forum. Download and save it. It's pretty big.
Old May 11, 2007 | 08:52 PM
Looks like the black/brown wire from the fuse box provides power to a bunch of stuff, including the speed sensor.
Old May 11, 2007 | 09:31 PM
MarineHawk's Avatar
That diagram's a lifesaver, so much easier to read than just enlarging my pdf black/white diagram.
VTRFan
Jun 27, 2007 01:35 PM
vtrj
May 20, 2007 03:49 AM
wardo996
Mar 26, 2007 09:39 PM
wardo996
Mar 21, 2007 10:20 AM
Verne
Aug 15, 2006 07:31 AM
