Gas tank question
Old Aug 14, 2013 | 01:32 PM
bpw's Avatar
bpw
bpw is on a distinguished road
Gas tank question
Im doing a resto/custom build. I need a gas tank, I read somewhere there are differences in the years but cant remember where I saw it? Anyway i have a 05 vtr and was wondering what tanks will work...? All of them?
thanks
-Brian
Old Aug 14, 2013 | 01:45 PM
Wicky's Avatar
It depends on your location.
Old Aug 14, 2013 | 03:27 PM
bpw's Avatar
bpw
Im in the US its a US bike
Old Aug 14, 2013 | 03:36 PM
I think the tanks are the same but the sensor in them is different, either a low fuel sensor or float for the gas guage.
Old Aug 14, 2013 | 03:55 PM
WhOrD's Avatar
WhOrD is on a distinguished road
Correct me if I am wrong....But the newer US VTR's with the LCD readouts would likely be a different fuel sensor...the older VTR with analog gauges would be the float.
I have a 1998 VTR and my gas tank sensor is a crude looking float.
Don't get me wrong, fuel gauges are overrated...unless you are doing long haul trips...I always check my fuel tank each day and also every hour of riding. However, I live in CA, Bay Area Silicon Valley...there is a fuel station every couple miles. Back when I was in Michigan...not so much.
Old Aug 14, 2013 | 04:53 PM
cybercarl's Avatar
Yep you got that the wrong way around. The early models with analog instruments and a simple RLOD for low fuel uses a fuel sender in the tank. This does not float and remains at a set level so when the fuel drops to that level the light switches on. The late models with a digital dash and a fuel gauge will have a float inside the tank which moves up and down with the fuel level, hence the reason it tells you the amount you have in the tank.
Old Aug 14, 2013 | 05:16 PM
I hugely disagree. I upgraded my 98 to have a fuel guage (and digital dash & speedo) and its a million times better than opening your fuel tank or waiting for an archaic low fuel light. (or worse just running out & switching to reserve)
If you count miles you can never be sure of consumption since city & hiway are so different.
Old Aug 14, 2013 | 05:38 PM
Jack Flash's Avatar
Well take off, eh.
If ever you get a pre '01 gas tank for your '05, and wish to keep the sensor
in your dash, it can easily be done. Just swap the sensor, and before inserting the float type sensor back in the tank, you need to bend the float arm a little in order for it to clear the internals inside.
Pre '01's have different internals then post '01, so, if you wish to keep accurate gas readings, that's the way to do it.
CentralCoaster
Oct 10, 2009 03:21 PM
Tom Blum
Dec 16, 2007 06:42 PM
B R
Apr 21, 2007 09:02 PM
StoneJrW
Feb 17, 2007 04:54 PM
nhowner
Sep 4, 2006 08:09 AM
