Fuel Gauge Issue
Old Apr 4, 2012 | 08:22 AM
Patton303's Avatar
Patton303 is on a distinguished road
Fuel Gauge Issue
I have a 2003 mostly stock SuperHawk and the problem I'm having is the fuel gauge is flashing that it's empty even when there's a full tank. Is there a sensor I can clean or adjust myself ? I got a one year warranty but I don't want to lose out on riding for a few days while they fix it.
-peace
Old Apr 4, 2012 | 12:37 PM
There is a sensor, yes, but it won't do much good to clean it... It's either busted and needs replacing, or not connected... Look in the service manual, it's linked as a download in a number of forum posts (search)... The manual lists tests for verifying it's condition, and by looking at the schematics you can locate the connectors along the way to check if properly seated...
I'd say it's worth the time to have them replace it once you have done the diagnosis for them... Or you might find one of the connectors unplugged (common) and fix it in ten minutes...
Old Apr 5, 2012 | 04:27 PM
Patton303's Avatar
Thanks much my friend...
Old Apr 5, 2012 | 05:57 PM
Wouldn't a disconnection cause no light at all? It did for me but maybe some other disconnection.
Old Apr 5, 2012 | 06:10 PM
aja's Avatar
aja
The manual says to unplug the connection under the seat and the light should come on, but mine doesn't and doesn't come on when the tank is low
Old Apr 5, 2012 | 11:36 PM
There's a difference between fuel gauge and RLOD... Just saying...
Old Apr 6, 2012 | 04:05 AM
CrankenFine's Avatar
-peace
I recently did some work on mine requiring removal of the tank. I had the exact condition you describe when I forgot to reconnect the sending unit wires.
Old Apr 8, 2012 | 05:32 PM
Patton303's Avatar
Got it working. It was indeed disconnected under the seat. The default warning signal for this disconnect is that it will flash the indication that it's empty. Thanks for all of your insight friends.... It helped a lot.
Old Mar 13, 2020 | 03:28 PM
Allie Wilbur's Avatar
Allie Wilbur is on a distinguished road
Info
where is this wire that comes undone mine is constantly saying it’s low also
Old Mar 13, 2020 | 04:08 PM
Wicky's Avatar
It comes from the back of the tank and runs to where it plugs into the loom near the battery.
Old Mar 14, 2020 | 05:30 AM
The 2 wire connector is in a bundle, in a large plastic protector just behind the fuel tank
Old Mar 14, 2020 | 01:33 PM
Ok
I checked my wire the two coming from under tank (green/black and white/black the connection looks brand new if that’s not undone what else could cause my gage to always blink low fuel
UOTE=E.Marquez;411659]The 2 wire connector is in a bundle, in a large plastic protector just behind the fuel tank
[/QUOTE]
Old Mar 14, 2020 | 05:20 PM
[/QUOTE]
On the first gen bikes, '98-'00, there is a some what higher failure rate of the fuel level sending unit. Don't know if the 2nd gen has the same issue, but worth checking.
Markt2143
Sep 26, 2015 06:46 PM
turbotim
Jul 24, 2014 12:16 PM
Munk
May 16, 2013 04:44 PM
General Maximus
Jun 26, 2010 07:30 PM
BIG DAVE 03
May 17, 2007 03:41 AM
