front sprocket seal
Old Feb 12, 2021 | 09:03 PM
Emmettvtr1000's Avatar
Emmettvtr1000 is on a distinguished road
front sprocket seal
i have an oil leak coming out of the front sprocket its the seal behind it is it easy to fix looking at the haynes manual it dose not say much or dose the motor has to come a part any help will be grateful any instruction
Old Feb 13, 2021 | 01:45 AM
Wicky's Avatar
Check first it's not an over oiled chain or hydraulic fluid from a leaky clutch slave.
https://www.superhawkforum.com/forum...il-seal-15727/
https://www.superhawkforum.com/forum...t-shaft-15679/
Old Feb 15, 2021 | 10:21 PM
CaryDG's Avatar
I've done this on mine and several other SH's; Remove Nut, Counter shaft Sprocket, Seal Sleeve from shaft, O ring from shaft, I then used an exhaust spring hook tool and levered the old seal out. Being careful to not gouge the case/seal surface. Thoroughly clean the area where old seal was seated. I use Honda Bond or any silicon gasket goo to sparingly coat the outer edge of the new seal to lubricate for installation and seal upon completion. I put a new O ring on the counter shaft. What works for me is to insert the seal bushing/spacer into the new seal. This helps center the seal in the case. Slide the seal and spacer assembly on to the counter shaft. I use a large, deep old bushing of the correct diameter I had in the shop and Carefully tap the driver with a hammer until it's seat evenly flush with the inside edge of the slight beveled inner edge of the seal area in case. If you don't have access to a proper driver (just slightly smaller than the outer diameter of the seal and longer than the counter shaft ) I've used large drift (1/4", 6-7mm, etc.), socket extension, or whatever. I know people that have used PVC, ABS and steel pipe with success. You can do this!
lynchie
Aug 7, 2008 02:28 PM
lynchie
Aug 6, 2008 08:27 PM
Pacatac
May 16, 2008 07:21 AM
flngscout
Nov 20, 2007 01:53 PM
robert
Oct 13, 2004 01:50 AM
