Seal behind drive gear.
Old Oct 13, 2004 | 01:50 AM
Rollingalong's Avatar
Rollingalong
Re: Seal behind drive gear.
Just pull the countershaft sprocket , make a hook tool to pull the seal out and using the old seal along with a socket of the near same OD drive the new one in . Easy as that .
I would though make certain the case surface is clean and use some locktite blue on the new seal soley as a lubricant to help slip in a bit easier .
Thats a high heat area and the seals take a hit . Synthetic oils usually run 20 degrees cooler than dino so over the life of the bike the potential for all engine seals in dynamic operation to last longer are better to a degree with synlubes in the motor from day one .
maniac2313
Jun 28, 2011 04:53 AM
motormouth
Mar 21, 2010 09:46 PM
SkullHeadNoPants
Oct 17, 2008 03:28 PM
codfish124
Jun 30, 2008 04:45 PM
Laynout
May 1, 2008 10:09 AM
