Front APE CCT Adjustment
Old Mar 25, 2010 | 03:22 AM
Whittaz's Avatar
Whittaz is on a distinguished road
Hi all,
My bike's been fitted with APE tensioners, adjusting the back one is fine but the front is hidden behind a radiator hose. Is there an easy way to adjust the front tensioner?
Thanks
Old Mar 25, 2010 | 05:49 AM
psyclown's Avatar
psyclown is on a distinguished road
When I did mine I had the fairings off and it was simple to drop the left radiator (2 bolts I think). Removing the fairing is not difficult or very time consuming.
Old Mar 25, 2010 | 07:37 AM
Little_Horse's Avatar
2nd mouse gets the cheese
or you can lift the tank like a lid remove the air box adjust and reconnect everything. I don't know what is more of a pain though. If it was me I would remove the airbox, I have done it so many times it would be a ten minute job.
Old Mar 25, 2010 | 09:12 AM
RK1's Avatar
RK1
I adjust the shaft itself with a shallow socket on a ratchet. I can't lift the ratchet handle enough to get a perfect fit, but the shaft moves easily and it works for me. On my bike at least the rad hose only blocks the lock nut. I slide a long, narrow screw driver under the hose and pry it up a little. That gives me enough room to get at the lock nut.
Old Mar 25, 2010 | 10:26 AM
ranchomice's Avatar
Push the hose down (wedge something) and use a narrow boxed end wrench.
Old Mar 25, 2010 | 02:08 PM
jay956's Avatar
ratchet, crows feet, various extensions, swivel thing, and lost of cussing
Crashrat
Oct 11, 2012 08:25 PM
YTKinWI
Aug 6, 2009 06:17 PM
Verne
Oct 3, 2007 03:23 AM
njrider
May 20, 2007 07:41 PM
thegreep
Dec 29, 2005 11:33 AM
