Fan switch
Old Apr 10, 2012 | 10:46 AM
Fan switch
So I am looking for a fan switch that will come on at 90* (C).
I tried an 80* switch but thats too low and it runs constantly.
Anyone know where I can find one? There has to be a Honda car that shares the switch right?
Old Apr 10, 2012 | 11:12 AM
From a Nissan car:
part #21595-01A00
Turns on at 85* C
Old Apr 10, 2012 | 11:40 AM
Manual switch, turn it on whenever you want.....
Old Apr 10, 2012 | 02:33 PM
Yeah I have a switch but kinda have a few things to do maneuvering through NYC traffic to be monitoring that.
Just went to 2 auto parts stores & no luck. I want to try for a 90* turn on but thanks 007 I can use that as a backup
Old Apr 10, 2012 | 10:15 PM
Ok I am gonna go ahead and bump this. I havent found a switch. I bicycled 18 miles today & went to several auto stores but no dice. It is really hard to back track these things.
I know its 18 threads x 1.5 and I want 90* (C). Some geo metros have similar ones but I cant find their temps. Also a suzuki swift seems to be similar but same issue.
So again I am calling on the SH army for help. I know you guys can find this.
Old Apr 10, 2012 | 10:22 PM
saige's Avatar
the boss
if i remember correctly,a switch from a honda car will work,im not 100% sure,but i believe from crx,most civics,integras.
i have the info saved somewhere,if i find it,i will give you exact info on it.
i was looking for switch before and found info by mistake.so i will get cracking on it.
what switch do you have on the bike now,the original that came with bike or a rigged one.
Old Apr 10, 2012 | 10:43 PM
Kinda both. The original switch plus a toggle to flip on. I even installed a (really) cheap digital thermometer to monitor coolant temp so I am in touch, thanks saige
Old Apr 11, 2012 | 09:36 AM
So what if I find a switch that has 2 contacts? Do I just need to run one to ground & then it completes the circuit? The stocker has only one contact..
Old Apr 11, 2012 | 10:43 AM
Yep. A lot of car switches have a separate ground contact rather than grounding through the radiator body. Just run a wire like you said.
Old Apr 11, 2012 | 12:43 PM
maniac2313's Avatar
maniac2313 is on a distinguished road
Reason being rads in cars have mostly plastic tanks and mounted in rubber gromets so they dont ground to anything...
inderocker
Apr 26, 2010 06:44 PM
Erik S.
Jun 27, 2008 01:21 AM
Tysonb
Jun 1, 2008 08:36 PM
mikstr
Apr 14, 2007 05:15 PM
RickB
Sep 13, 2005 09:05 AM
