Electrical Problem, Hawk completely dead
Old 10-26-2008, 04:24 PM
rahjer's Avatar
rahjer is on a distinguished road
So I'm out running errands and the Hawk yesterday, everything running just fine. When I came out of a store and started the bike, it fired up then immediately died. Hit the starter button again and nothing. No lights, no odometer, no nothing.
Checked all the fuses in the fuse box, but all okay. Took the tail section off and checked the main 30amp fuse, and it was okay. Just got a new pickup and ramp, so this was a perfect time to try it out.
Got it home. Tested the battery and it was fine (12v), tested the hot wire at the starter relay (???, where the 30amp fuse is), and it was fine (12v), but nothing on the side running to the starter, with key on and starter button pushed. Pulled the wire harness off and there was 12v at 2 of the pins, and I'm assuming the other two were ground.
Is it my key/ignition switch not letting power out of the starter relay, or letting it go anywhere else? I checked all the wiring and it seemed just fine (nothing loose or corroded). The bike is a '99, but I replaced the ignition switch about 4 years ago after someone tried to steal it (Thank you Krypton brake rotor lock!).
Any ideas would be appreciated... I've got a track day coming up in November. Thanks.
Roger
rahjer is offline
Old 10-26-2008, 07:10 PM
Well if you get no lights etc, then it isn't the relay.
Your R/R is probably bad, double check the 30A fuse.. And upgrade your R/R
lazn is offline
Old 10-26-2008, 07:56 PM
http://vtr1000f.wickidnet.com/ Check this link out for the R/R job
smokinjoe73 is offline
Old 10-26-2008, 08:38 PM
Long Member
flyin_hawk's Avatar
flyin_hawk is on a distinguished road
My R/R shorted and the bike went dead but it blew the main fuse and would blow them as soon as they were replaced. If your fuse is still good....I dunno.
flyin_hawk is offline
Old 10-26-2008, 08:55 PM
Ground cable?
inderocker is offline
Old 10-26-2008, 09:22 PM
Slacker
BeerHunter's Avatar
Sounds like the ignition switch may be faulty.
To test it remove the 3 bolts holding the instrument cluster (don't lose the metal spacers and thin rubber washers beneath the bolt heads). Pull the cluster out a little and turn it sideways, then lay it to the left. Pull the 3 wire connector (Red - Red/Black - Blue/Orange) from the weather boot on the right side and unplug it... check for corrosion. There will be two parallel female terminals in the harness side of the plug. Put a jumper wire between those 2 (Red - Red/Black) The lights should all come on. If so then the ignition switch is bad.
This should take less than 10 minutes, but the connector may be difficult to unplug.
BeerHunter is offline
Old 10-27-2008, 10:29 AM
rahjer's Avatar
I'm gonna take the fairing off today and I'll check the ignition switch and wiring.
I should have mentioned that I had R/R problems about a year ago, and finally solved that by putting in a Yamaha R1 rectifier. This problem doesn't match the symptoms I was having when my original R/R and Honda replacement R/R went out. The battery still has full voltage now, and this time the big went dead instantly.
I checked the 30 amp fuse with my meter and it checked out fine.
I'll see what the ignition wiring looks like now.
Roger
rahjer is offline
Old 10-27-2008, 11:50 AM
RickB's Avatar
I had a battery have an instant failure (cranked a turn or 2 and everything went dead) once where it would read 12v on the voltmeter but dropped to zero when the ignition was turned on or any load was put on it... Not a common failure but easy enough to test. I am leaning toward the ignition switch being the issue like was mentioned by beerhunter since you tested the main fuse already.
RickB is offline
Old 10-27-2008, 02:57 PM
rahjer's Avatar
So I jumped the two wires off the ignition switch and the lights came on. The connectors were a little corroded, so I cleaned them up and plugged it back in.
I'm glad you mentioned that about your battery. Mine reads 12.56v, but when I jump the wires the lights come on, but not very bright. I hooked up my battery charger and the lights come on brights as usual. Then I hit the starter and it's still not turning over, but I'm getting a strange fast clicking noise out of the converter unit. Not even sure what that does, it's the smaller box on top of the Ignition Control Unit in the tail. The wiring diagram shows a hot wire going in, two leads coming out to each of the coils, then three leads going out to eh Ignition Control Unit.
I've got an older battery here, so I'm gonna put that on the charger then swap that in and see what happens.
Could my starter motor be seized? When I checked it yesterday I was getting 12v to the starter relay, but nothing coming out. Now it reads 12v going to the starter relay, and 12v going out to the starter.
I'm an electrical novice, just know the basic and how to use a multi-meter. Any help would be appreciated as my local Honda dealer charges an arm and a leg, and I'm not real confident in their service techs anyway. The place I used to take it is now an hour away.
Roger
rahjer is offline
Old 10-27-2008, 05:48 PM
HollywoodAngel
HollywoodAngel's Avatar
HollywoodAngel is on a distinguished road
Sounds like when my volt regultaor went
Couple of years ago my 98 Hawk started doing weird stuff like that. I'd ride it 20 miles on a freeway to work, and then sop at a 7/11. When I went to restart, starter so weak it couldn't turn engine over. Later that same day, am riding around Palos Verdes estates, looking for our location, and I start to lose gauges and dash lights one by one. Tach goes out, then the hi-beam light, then the neutral light, then the speedo, then the bike quits. no lights no nothing. Turn key on and off three times, lights come back, and i'm back on the road. turned out to be the $200 regulator. I wish i could tell you how to quickly check this...
HollywoodAngel is offline
Old 10-27-2008, 06:18 PM
Gregw's Avatar
At least with cars, that noise sounds like it's the starter solenoid. It'll make that clicking sound when there isn't enough amperage in the battery. I'd give it an overnight charge and see if that takes care of your problem.
Gregw is offline
Old 10-28-2008, 02:30 AM
Yup, the clicking should be the solenoid... Try it with a fresh battery...
And once you get it all running... Go over, every connection... and I mean every one... and find any and all that have corrosion and then fix it... it drains more than you might think...
Tweety is offline
Old 10-28-2008, 02:42 PM
ascothawk's Avatar
ascothawk is on a distinguished road
I recently replaced a failing starter solenoid on my 59,000 mi. "98.Sometimes it would turn over first push of the button,sometimes 3 or 4 tries.Just solenoid click.Always had lights&full charge on battery.Tested 12.9V at pos. cable side of solenoid,.2V at starter cable side when the button was pushed.Got one off a low mi "04 on ebay for $10.00.Service Honda shows same part # for 98 thru 04,different # for 05's.
ascothawk is offline
Old 10-29-2008, 07:24 PM
rahjer's Avatar
I just popped in an old battery that's been on the charger for a few days, and the Hawk fired right up. Wierd. The battery I pulled out still reads 12.45v.
Since I have the fairing and tail section off the bike, I'm gonna go ahead and check all the connectors. Just to be sure. It's getting long in the tooth, and I don't baby it.
Thank you guys very much for all the input!
Roger
rahjer is offline
dshakes
08-03-2012 06:45 AM
Duck007
01-10-2012 09:03 AM
koth442
05-12-2011 10:31 AM
maverick
06-07-2009 06:40 AM
98VTR
07-10-2008 10:37 AM
Quick Reply: Electrical Problem, Hawk completely dead
