Dunlop qualifiers track pressures.
Old Jun 6, 2006 | 05:04 PM
AZZKIKER's Avatar
What should I run for tire pressures on the track. I guess I read somewhere that for pilot powers if you run them lower than 37 psi they tend to get hot and greasy. So I am wondering about the qualifiers.
Old Jun 6, 2006 | 05:38 PM
Brian A's Avatar
I have NEVER run 37 psi in the Pilot Powers. I ran 30 rear / 28 front and had great results. Both on and off the track.
But that wasn't the question.
I started at 34 rear and 32 front with the DQs when I did a track day at Barber last month. Front end slid real bad one time and I started dorkin around with tire pressure a little.
Guess where I wound up?
30 rear / 28 front and they worked great.
Check with the Dunlop guy at the track. I'm guessing those area about what he will suggest you start with.
Old Jun 6, 2006 | 06:10 PM
AZZKIKER's Avatar
ok, I will try that, thanx for replying so fast.
Old Jun 6, 2006 | 07:00 PM
superhawk22's Avatar
30/28 +1 I did the same thing with dicking around and ended the same place I've used with all my tires.
Old Jun 6, 2006 | 07:06 PM
marmaladedad's Avatar
Hmm?
30/30 is where I like to start. The Michelin rep I spoke with suggested 38/38 for the Pilot Powers, and they worked well for my friend. Just start with a baseline, and go from there. If the tires look like they're still brand new when you pull in to the pits, lower the pressure. If they look completely roasted, raise it a little.
Old Jun 6, 2006 | 08:28 PM
twitcher's Avatar
twitcher
Yep, 30/28 is the go. Guys, how are your Qualifiers holding up? I've got about 1000 miles on mine including a track day and they seem to be wearing well. Anyone finished a set off yet?
Old Jun 6, 2006 | 09:21 PM
2 track days and about 500 miles and they still look great so far. I'm going to try and get 2 more track days out of them the 23rd and 24th but I'm not sure if that's pushing it too much.
Old Jun 7, 2006 | 01:48 AM
You gotta be kidding? 38 f/r on Powers? I know the Pilot Race and the Pilot Power have a very similar carcass, and the Mich guys recommend like 24 on the rear, 28 on the front, IIRC. That just seems wierd on the track....like they WANT you to crash?
996er
Jul 18, 2008 09:42 AM
twitcher
May 22, 2006 07:55 AM
FRANKSVTR
May 4, 2006 10:55 AM
Brian A
Mar 10, 2006 10:36 AM
superchicken
Jun 8, 2005 11:22 AM
