directional woes
Old Jul 30, 2006 | 12:17 PM
willie's Avatar
willie
Question directional woes
Hey guys,
I have a uniqe problem with the directionals on my sh. It has clear lens front & rear directionals with amber bulbs. I had a rear bulb blow on me last week so I pulled the bulb and went to the local napa. The bulb has no markings on it except 12v23w, wich is fine but it doesn't give a number for cross referencing. The bulb looks exaclty like a 97NA bulb.
When I put a new bulb in, the directional(s) (left side front & rear) will work but they blink twice as fast as the right side of the bike. So I switched the bulbs to the other side & the same thing happens except it's now on the right side. I'm guessing the new bulb may have a differnt resistance in it? Any ideas of what the problem might be?
Thanks
Old Jul 30, 2006 | 12:50 PM
CNI Dawg's Avatar
You may need an 1156 bulb not 97NA
An 1156 draws 26 watts and a 97NA only draws 8 watts (it's also a 13 volt bulb vs 12 volt)
The flasher relay works off resistance.
If the bulbs are not drawing enough power the relay senses this & flashes fast to let you know there is a bulb out.
In your case the bulb you replaced is not drawing enough power to let the relay know it's there & working.
Try an 1156 bulb & it should solve your problem
http://www.donsbulbs.com/cgi-bin/r/b.pl/97na.html
http://www.donsbulbs.com/cgi-bin/r/b.pl/1156.html
Old Jul 30, 2006 | 07:00 PM
thetophatflash's Avatar
The bulbs you have are from Lockhart/Phillips. I made a comprehensive search about 18 months ago and didn't find any on the internet. The L/P numbers are as follows: 122-9600,single filament; 122-9603, dual filament. let me know if you find another source.
Old Jul 31, 2006 | 04:59 AM
willie's Avatar
willie
thanks guys,
an 1156 bulb is the same size as an 1157 coorect? if so it is way to big for my application. Although I still need to look at your links.
I did look in my lockhart catalog last night & found the part number........
thanks again guys,
willie
Old Jul 31, 2006 | 04:56 PM
Do yourself a favor....ditch the LP signals. The bulbs they use suck donkey ***** and you may as well just go ahead and order them in dozens. They will burn out about 1 every month until you get sick of them. They ain't worth the trouble. Get some LED signals and some 20 watt resistors and wire them in parallel with the signals.
I just recently ditched my LP type IV (small cheap arrow looking ones with the dual filiament bulb - thought it would be cool to have running lights in the rear until BOTH of them burned out from the vibration) and bought some Hyperlites. I got the ones that have the flashing brake light, red running light, and turn signals all in one. I had a VFX flash equalizer laying around the garage and 2 hours later and it's a nice clean install. These little puppies are BRIGHT too! I will NOT get run over from the rear with these on. I'll post pics if anyone's interested.
Old Aug 1, 2006 | 04:12 AM
willie's Avatar
willie
Hey Greg,
if you don't mind could you post a pic?
Thanks
Old Aug 1, 2006 | 09:45 AM
Yeah, but it'll have to be tonight late. I'm working swings right now.
Old Aug 2, 2006 | 01:09 AM
As promised to another lister...pics of the Hyperlites. First is running lights. These flash on-off when the brake is applied. Second pic is with the left signal on.
Old Aug 11, 2006 | 02:26 PM
Chilly996's Avatar
Chilly996 is on a distinguished road
What do they look like in the daytime? I mean their appearance in general. It's so dark.
Old Nov 2, 2006 | 10:26 PM
Bringing this one back from the dead because I never saw Chilly's question. Happened upon this thread because I was doing some research.
Anyway, check out this link. These are the ones I have.
http://www.hyperlites.com/3Way.html
vtrwillie72
Mar 15, 2012 11:55 AM
Gerrit
Feb 13, 2008 06:00 PM
MisterMohawk
Apr 17, 2007 01:44 AM
L8RGYZ
Sep 26, 2006 07:13 AM
Racer647
Aug 21, 2006 10:22 PM
