Dies Under Hard Braking
Old May 31, 2015 | 03:48 PM
Big_Jim59's Avatar
I know this has probably been covered before but I noticed that if I am coming to a stop, and slow down gradualy, all is fine. If I stand it on it nose the RPMs will drop and it will die. What have I missed?
Old May 31, 2015 | 03:55 PM
Wicky's Avatar
There's a carb overflow hose that runs through the carb brackets that's routed through a tight bend that can get kinked - take a peek underneath the airbox next time you're under there. Symptoms as you've described are for it to happen under ermergency heavy braking.
Old May 31, 2015 | 04:08 PM
NZSpokes's Avatar
Mine had this and I moved the breathers to face down. It would get a bit exciting on the track when it did it.
I believe there was a Honda service bulletin on it.
Old May 31, 2015 | 04:30 PM
Big_Jim59's Avatar
I know exactly what you are talking about. They are the only hoses I didn't mess with. They still have the original dust and grime on them. I'll take a look the next time I have the air box off.
I have started to compensate by pulling the clutch and rolling the throttle on a bit. For me, it's too much to remember when you have cars to worry about.
Old Jun 1, 2015 | 05:56 AM
AndyMX47's Avatar
Suffered from that issue - pulled the carb vent lines out of the carb braces, pointed them straight down, trimmed the ends at an angle - no more issue.
Old Jun 1, 2015 | 12:00 PM
Big_Jim59's Avatar
Thanks everyone. I guess I'll have to pull the air box one more time. It would be so bad but I filled the tank. Isn't that they way it always works?
Old Jun 3, 2015 | 08:14 AM
AndyMX47's Avatar
With patience you can re-route the vent lines with tank and airbox in place
Old Jun 3, 2015 | 09:00 AM
Spoot's Avatar
über-n00b
Spoot is on a distinguished road
I ran them straight, but I still have issues once in a while at the track.
4 or 5 times at Road America yesterday, iirc.
As stated...under heavy braking. Irritating.
Next time I'm in under there, maybe I'll try the 'pointed down' and angle cut hoses.
Old Jun 3, 2015 | 01:40 PM
NZSpokes's Avatar
Something I remembered that is very important. In fact it should be a sticky.
Cut the rear hose shorter if you do this. I had the hose get stuck under the throttle stop on the carbs and jammed the throttle wide open. I had this just before a turn.
Cut the hose so it cant reach the carb stop for the throttle.
Old Jun 3, 2015 | 08:57 PM
Spoot's Avatar
über-n00b
^oh my....another good thing to look for.
thnx!
Old Jun 5, 2015 | 09:58 AM
It is only the front carb which needs the line rerouted and there is no need to cut angles in the hoses.
If you want you can shoot me your e-mail and I can send you a copy of the bulletin
Old Jun 5, 2015 | 01:15 PM
Mike, is there anything wrong with simply removing the hoses? Or actually, just the front hose.
Old Jun 5, 2015 | 01:27 PM
CrankenFine's Avatar
I think this something that could be useful if posted in the knowledgebase.
Old Jun 5, 2015 | 03:31 PM
No, or at least I have run mine without the breather hoses for a bit over 10 yrs now with no problems.
Spoot
Aug 21, 2013 08:54 PM
meanhawk98
Feb 13, 2012 11:27 AM
natewill
Jun 19, 2011 04:42 PM
gpzturbo
Oct 14, 2010 03:04 PM
ClevelandSuperhawkRumble
Apr 29, 2007 08:03 PM
