Dies Under Hard Braking
I know this has probably been covered before but I noticed that if I am coming to a stop, and slow down gradualy, all is fine. If I stand it on it nose the RPMs will drop and it will die. What have I missed?
There's a carb overflow hose that runs through the carb brackets that's routed through a tight bend that can get kinked - take a peek underneath the airbox next time you're under there. Symptoms as you've described are for it to happen under ermergency heavy braking.
Mine had this and I moved the breathers to face down. It would get a bit exciting on the track when it did it.
I believe there was a Honda service bulletin on it. |
I know exactly what you are talking about. They are the only hoses I didn't mess with. They still have the original dust and grime on them. I'll take a look the next time I have the air box off.
I have started to compensate by pulling the clutch and rolling the throttle on a bit. For me, it's too much to remember when you have cars to worry about. |
Suffered from that issue - pulled the carb vent lines out of the carb braces, pointed them straight down, trimmed the ends at an angle - no more issue.
Thanks everyone. I guess I'll have to pull the air box one more time. It would be so bad but I filled the tank. Isn't that they way it always works?
With patience you can re-route the vent lines with tank and airbox in place
I ran them straight, but I still have issues once in a while at the track.
4 or 5 times at Road America yesterday, iirc. As stated...under heavy braking. Irritating. Next time I'm in under there, maybe I'll try the 'pointed down' and angle cut hoses. |
Something I remembered that is very important. In fact it should be a sticky.
Cut the rear hose shorter if you do this. I had the hose get stuck under the throttle stop on the carbs and jammed the throttle wide open. I had this just before a turn. Cut the hose so it cant reach the carb stop for the throttle. |
^oh my....another good thing to look for.
thnx! |
It is only the front carb which needs the line rerouted and there is no need to cut angles in the hoses.
If you want you can shoot me your e-mail and I can send you a copy of the bulletin |
Originally Posted by 8541Hawk
(Post 386950)
(Post 386950)
Originally Posted by CruxGNZ
(Post 386964)
Mike, is there anything wrong with simply removing the hoses? Or actually, just the front hose.
