dead fuel pump, bent valves?
Old Apr 10, 2011 | 06:57 PM
nykuryu's Avatar
nykuryu is on a distinguished road
ok so heres where im at. i tried starting the bike today, and wow it actually started. however i had the adjusters loose and the cam chain noise freaked me out so i killed the engine. i then started it again after calming down and tried to adjust the chain, but it died before i could do it. i tried restarting it......i killed the battery. so i took it back inside to check timing, all was spot on cept the front intake was a tooth "late" in the chain. did i just bomb the front cylinder? i fixed it went back outside checked for spark, BAM have it. but i didnt smell any fuel....stick my finger in the spark plug wells....no fuel. i check the plug where the pump goes and i have about 11v with just the ignition on. i check the contacts on the underside of the pump 0.0v. i also turned the petcock both ways to make sure i actually turned it back on. the 2 big lines are in the right spots and the little line from the carbs to the tank is there. am i missing anything?
Old Apr 10, 2011 | 07:06 PM
Well there is no fuel pump, that is the fuel light or gas gauge wiring......
Having the cam one tooth off shouldn't have hurt anything. As for no fuel, make sure it is flowing out of the petcock and also open the bleed screw on the bottom of the float bowl to make sure the carbs are getting fuel and then go from there.
Old Apr 10, 2011 | 07:10 PM
nykuryu's Avatar
oooooo i feel like an ***, my SRAD have a pump for the carbs. ok ill check those
Bandit400man
Jul 25, 2013 09:02 AM
BURNOUTS MC
Jun 7, 2012 07:51 AM
john3012
May 31, 2011 06:42 PM
dickard37
Jan 13, 2010 02:00 AM
Texassuperhawk
Feb 28, 2007 03:20 PM
