coil grounds
Old Jun 16, 2010 | 10:24 PM
jay956's Avatar
coil grounds
the tab coming off the frame for the front coil broke off. got a piece of thick safety wire holding it in place so it doesnt shake around. seems to run fine although ive only been around the block a few times since this has happened. is it fine like i have it or should i try to get that tab welded back on?
Old Jun 17, 2010 | 03:51 AM
bjorn toulouse's Avatar
Destructive Tester
If you were to install a set of CBR coils, the broken bracket wouldn't be an issue. Prolly cheeper than having the bracket TIG welded.
Just sayin'.
Rex
Old Jun 18, 2010 | 09:01 AM
onesickxp's Avatar
onesickxp is on a distinguished road
I did the cbr coils last night what an easy mod, Works great
Old Jun 18, 2010 | 01:24 PM
nothing's Avatar
ride it out
how are cbr coils a mod?
Old Jun 18, 2010 | 01:26 PM
onesickxp's Avatar
mm maybe because they dont come stock on the bike. completely diffrent design. use search.
Old Jun 18, 2010 | 01:32 PM
onesickxp's Avatar
https://www.superhawkforum.com/forum...ad.php?t=22773 Heres a write up I found.
Old Jun 18, 2010 | 04:49 PM
jay956's Avatar
well i rode to work the last 2 days and it seems fine so i itll prbably stay this way for a while
Old Jun 28, 2010 | 09:24 PM
viperkillertt's Avatar
Josh
viperkillertt
Any update? I am tempted to try it. I ordered a harness, but i havent got the coils yet.
Old Jun 29, 2010 | 05:58 PM
jay956's Avatar
not sure what you mean.. i havent switched out coils, just safety wired my old one
Old Jun 29, 2010 | 06:38 PM
https://www.superhawkforum.com/forum...ad.php?t=23004
Do the MOD, it's cheap, easy and works.
Old Jul 2, 2010 | 02:56 PM
Rama's Avatar
Rama is on a distinguished road
but are you sure that this mod give more power????
I think that the only reason about the tweety's bike go better on the dyno, was that his original coils are very old... i'm not sure that the cbr coils can give more hp...
Anyone after the cbr coils mod have find more hp??
Old Jul 2, 2010 | 03:31 PM
The best possible gain you will ever see on hp from that mod is so low it's probably within the margin of error on a dyno...
It will not gain you any hp... it's that simple...
Old Jul 2, 2010 | 04:13 PM
I think that the only reason about the tweety's bike go better on the dyno, was that his original coils are very old... I'm not sure that the cbr coils can give more hp...
Simple, easy and it works... I guess it was the word "works" that was confusing you.
I never intended this MOD to make more power. which is good, as it wont unless you have an issue with the OEM coils and spark plug leads you have on there now.
What it does do is clean up some wiring, remove the weight and bulk of the OEM coils, and, at least for me, cure a misfire I had from what I believe was a faulty spark plug lead on the rear coil.
So for me, it works as designed and planed.. Can't get much better results than that from a MOD IMHO
ff
Mar 30, 2010 07:32 AM
maverick
May 19, 2009 06:26 AM
skoshere
May 6, 2009 09:39 AM
finepooch
Aug 14, 2008 04:32 AM
Markrs1980
Apr 21, 2005 08:58 AM
