Clutch problem - Please help!
Old Apr 23, 2013 | 12:58 PM
JasChen's Avatar
JasChen is on a distinguished road
I have a 99 VTR1000 that I normally ride in the summer. I hopped on a few weeks ago and noticed the clutch was very soft. So after starting it and warming it up and pumping it nothing helped. When I tried to engaged it into the first gear, it seems like I was already in gear and I stalled like I forgot to engage the clutch.
After a few inspections I noticed the clutch fluid reserve was empty. I flushed the clutch system and got the clutch feel was back, but the clutch still didn't disengage. Just like I"m in first.
Is my clutch cable gone? My master cylinder gone? Clutch/plate gone?
Thank you for the help.
Old Apr 23, 2013 | 01:10 PM
cybercarl's Avatar
No clutch cable on these as they are hydraulic. Sounds like you have a leaky seal somewhere. I would strart with the clutch slave cylinder on the sprocket cover.
Old Apr 23, 2013 | 01:12 PM
sailorjerry's Avatar
also check the rod that pushes the clutch appart from the slave and make sure it is intact and not sticking, and make sure that the system is properly bled, one little air bubble can cause a whole lot of issues. start pulling, open the bleeder, once clutch lever is all the way in hold it and close the bleeder, if you let go even the slightest bit it will pull air back into the system.
Old Apr 23, 2013 | 01:37 PM
Likely didn't bleed it fully. When flushing the system, bleed it like you would brake lines, but pump the clutch lever several times between bleeds. Watch the fluid reservoir for bubbles to come out... often they get trapped in the master cylinder and will cause the system to go soft.
Old Apr 23, 2013 | 01:43 PM
Personally at this point I would first remove the slave cylinder.
Take it apart and clean it.
Put it all back together and then bleed the system, but that is just me....
Old Apr 23, 2013 | 01:50 PM
You say that because...... it's a damn good idea.. I've worked on several VTR's now that had clutch issues, everyone of them had sludge in the slave cylinder.
A through cleaning of the slave cylinder, master cylinder, and a correct bleeding has fixed all but one, and it needed seals in the MC.
Old Apr 23, 2013 | 02:34 PM
JasChen's Avatar
So that's exactly what I'm going to try. I already bought a MC rebuild kit and I'm going to try and replace the internals. I'm also going to clean out the slave as well. I hope that fixes the problem. Thanks everyone.
Old Apr 23, 2013 | 02:57 PM
Wicky's Avatar
Do the slave first as that's easier :-) The m/c has a tricky internal circlip ;-)
With the slave if grit gets in there it can scratch the bore and leak hydraulic fluid around the gear lever, sidestand area. Wet&dry the bore smooth and replace seal if needed should fix. Other alternatives is that the Honda Blackbird clutch slave unit is a straight swap.
When bleeding keep filling the reservoir little and often so the fluid level doesn't drop introducing bubbles into the system. A large capacity 60ml catheter syringe with a bit of hose can be useful for drawing fluid down via the slave bleed nipple.
Old Apr 25, 2013 | 12:14 AM
JasChen's Avatar
Now that you mentioned it, I noticed my kickstand has an excessive amount of oil on it. It could be clutch fluid. Is there a rebuild kit for the slave?
Old Apr 25, 2013 | 02:03 AM
Wicky's Avatar
Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>LEFT CLUTCH SLAVE
Look on ebay
Old Apr 25, 2013 | 06:13 AM
From the ronayers link get part #6, 8, 9, and 15 Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>LEFT CRANKCASE COVER WATER PUMP
Recommend your "cleaning" fluid is brake fluid, and wash painted surfaces after cleaning so as to not stain the paint.
Old May 8, 2018 | 04:36 PM
Thatonedude303's Avatar
Thatonedude303 is on a distinguished road
I have a 2000 vtr 1000r and my clutch is doing the same thing. I can completely disengage clutch in gear and the engine revs but im not matching the speed. I'm stumped any help will work
Old May 8, 2018 | 06:50 PM
Remove, disassemble, clean the slave cylinder.
Flush the master cylinder.
Fill and bleed as normal, then back bleed the slave.
dannyz
Jul 19, 2010 07:21 AM
mattvdsande
Mar 16, 2009 11:12 AM
dustinwild
May 31, 2006 09:39 AM
The Hawk Guy
May 2, 2006 04:55 PM
AZZKIKER
Apr 15, 2006 07:31 AM
