brake rotor problem. Need help please.
Old Apr 11, 2006 | 06:48 AM
AZZKIKER's Avatar
hey guys. I need some help here please. When I took the bike out of storage this season I noticed some pulsation when braking. Mind you I have the gixxer calipers on there. So I lifted the front wheel off the ground and tried rolling it with my hand and found that the rotors where binding on the brake pads. The wheel would turn a couple times and it would stop. So I checked the rotors and wouldn't you know it, the left rotor is bent by about 1 MM. I did a search on this forum and I noticed people talking about the aluminum carriers. Now the question is, how do you work with the carriers to straighten the rotor out. Thanx
Old Apr 11, 2006 | 12:52 PM
AZZKIKER's Avatar
anyone????? First time I never got a reply right away. What's going on guys??? LOL
Old Apr 11, 2006 | 03:08 PM
shayne's Avatar
Re: brake rotor problem. Need help please.
I reckon you could stuff around forever yourself and this will still not be perfect. My advice would be to take it to a specialist with the right equipment to fix this for you.
And make sure you give them the wheel as well. I have had brakes done and after the fact found out the mount to the wheel was the problem.
Old Apr 11, 2006 | 04:53 PM
sprhawk neil's Avatar
are they superhawk rotors? you may be able to find some on fle-bay? If not I have a friend that works for honda in fla. and sells me parts at cost + 10% and I may be able to get free shipping let me know.I was hoping to ride with you to the blessing of the bikes!!!!!
Old Apr 12, 2006 | 05:01 AM
AZZKIKER's Avatar
Hey superhawk Neil. I will have the problem fixed today hopefully. I have stock rotors. I will let you know of the outcome and yes I have stock rotors. I am gonna take em to my friend's shop to run them on a feeler gauge and attempt to fix em.
Shayne are you talking about the aluminum carrier that connect the rotors to the wheel? yeah, I believe the problem lies there.
Old Apr 14, 2006 | 07:12 PM
AZZKIKER's Avatar
well, we fixed the rotor as much as we could. When the wheel is rolled, both rotors look straight. Pulsation is a lot less now, when the left rotor is STILL draggin. I took it off and rebuilt the left caliper and it is the same now. Could the rotor still be bent but not be visible???
Old Apr 14, 2006 | 07:15 PM
superhawk22's Avatar
Yep. Get a caliper to measure run out or go to someone who has one.
Old Apr 14, 2006 | 07:22 PM
You might want to talk to this guy about the rotors, he had the same problem.
https://www.superhawkforum.com/viewtopic.php?t=2168
Old Apr 14, 2006 | 07:35 PM
AZZKIKER's Avatar
Thanx for the link., What do you mean by "Get a caliper to measure run out or go to someone who has one"?
Old Apr 14, 2006 | 07:38 PM
It's a tool for measuring, I know it has another name but it escapes me at this time.
Old Apr 14, 2006 | 07:50 PM
It's like a micrometer that you can set up to measure run out.
Old Apr 14, 2006 | 07:52 PM
AZZKIKER's Avatar
That's what the machine shop used to straighten the rotor but they couldn't straighten it out all the way. I think I need a replacement.
Old Apr 14, 2006 | 07:57 PM
Did they do it on the wheel or by itself?
Old Apr 15, 2006 | 02:04 AM
shayne's Avatar
I think you may be referring to a dial indicator.
What I mean when I say a specialist may need the wheel, is that in my case, it was not the rotor or the carrier but the wheel itself that needed attention.
I rode off (or tried to) with a disc lock on......
That was on another bike. Unless you have had a get-off I think it would be unlikely that this would happen on the VTR. But if they have the wheel then all bases are covered.
Old Apr 15, 2006 | 04:07 AM
AZZKIKER's Avatar
The wheel is straight and yes they has the wheel/rotor combo. Thanx for your replies guys.
Old Apr 15, 2006 | 07:31 AM
Yeah that's the ticket, thanks I was having a brain fart!
mattvdsande
Mar 16, 2009 11:12 AM
Random
Aug 31, 2006 01:50 AM
cb21983
Jun 19, 2006 11:30 AM
dustinwild
May 31, 2006 09:39 AM
The Hawk Guy
May 2, 2006 04:55 PM
