Clutch is losing friction point
Old Mar 22, 2020 | 08:32 AM
MwCrf450R's Avatar
MwCrf450R is on a distinguished road
So I have a 05 SH. The clutch was great when I got it but over the course of a few hundred miles(maybe 500 tops) my clutch went from 100% normal to now my friction points way way out. To the point where if you move the lever the slightest it'll shift for you. One time the clutch even slipped but that was with a passenger, by myself it has never slipped. I was going to order a clutch kit for the bike but I was doing research and realized the clutch was on the right side and coincidentally there's a ever so small crack in the right hand crank case of my bike. I bleed the clutch last fall and my bike didnt improve or get worse so I still kinda think plates/springs. Any thoughts? Also I have a 98 that jumped timing but was having no clutch issues, would those parts all be interchangeable? Usually I wouldnt use old parts but I'm seriously considering robbing the crankcase cover as that ones solid, and if I'm that far in why not I suppose. If the crankcase doesnt fix it after swapping all the clutch components around I'll order new parts
Old Mar 22, 2020 | 09:25 AM
Air in system
Master or slave dirty
Clutch disk friction material deteriorating
Energy saving oil used and friction material is contaminated
Any time this model has clutch issues my suggestion is always, clean / inspect/ rebuild master and slave, use fresh fluid from a sealed container and belled the system, then back bleed, then bleed one more time normally. A somewhat short cut is to replace the slave with an Operon aftermarket unit...the cost is not bad and about /23 more then the rebuild parts,,,but you get a better slave cylinder that results in better feel.
A braided SS line is also a good upgrade for better clutch action and feel.
That corrects many issues, after that you pull the clutch cover and instact / measure the drive and driven disks, and spring free length
Old Mar 22, 2020 | 10:05 AM
MwCrf450R's Avatar
Air in system
Well if I'm gonna go through all the effort of tearing into my clutch system I'd rather put new parts back on haha. Oberon slave cylinder has been ordered. Thanks for your input E. Marquez.
But that still leaves me with my crank case cover, even if that isnt the direct cause of my problem it is still ugly and stove up. Anyone know how interchangeable the covers are?
Old Mar 22, 2020 | 10:31 AM
All the same other then color and the early years had just a water pump weep hole, later wns Honda pressed in a small J shaped tube.....
Makes no difference at all, they all interchange
Dont forget you will need a new gasket
GASKET, R. COVER
11394-MBT-000
https://www.partzilla.com/product/ho...e18e476781faf7
Old Mar 22, 2020 | 10:46 AM
MwCrf450R's Avatar
well it just so happens that I'm in luck cuz I was planning to get both sides powder coated right off maybe they'll be the project that finally convinces me to do it haha. Thanks for all the info you've been very helpful
Old Mar 22, 2020 | 07:54 PM
I agree with everything Erik said, plus I would first think of air in the clutch lines. Doesn't matter when you bled it. 1) You may have done it wrong 2) Air can get in at any time so yesterdays bleeding may not be good today. Air will take up space and "ride the clutch" all the time causing slip, plus overheat it also causing slip.
Open the cover, you don't even need to drain the oil, just tip the bike (a pile of tires works).
You can remove and examine the plates, then scuff them with sandpaper and/or a ball hone to revive grip levels.
Change the oil to remove the auto oil friction modifiers that may be causing it. Some will have seeped in but you can brakecleen the plates to alleviate some of the issue. Then scuff and reassemble with the bled hose and you are very likely to feel huge improvement if not a full cure.
Old Mar 23, 2020 | 12:20 AM
Cadbury64's Avatar
VTR virgin
I would think the symptoms point to a blockage in the tiny compesation port in the floor of the master; this allows pressure to release from the line after you've used the clutch. If that blocks you will build more pressure in the line to the point where the slave can't retract, causing the clutch to slip. I'd try cleaning the master carefully first.
If you had air in the line, you'd have the opposite problem i.e. you'd have to pull the clutch all the way in to shift, and it wouldn't slip. And I would expect wearing plates or spings to be a gradual fault developing over many thousands of miles.
Old Mar 23, 2020 | 06:47 AM
ascothawk's Avatar
ascothawk is on a distinguished road
I always replace the clutch springs if I'm going to disassemble the clutch
,their the the cheapest part of the assembly. I replaced a slipping clutch on a Honda Pacific Coast years ago that slipped under load in high gear. New plates and and friction discs, it still slipped. a $15.00 set of Barnett springs fixed it. The Barnetts and EBC springs are about 10% stiffer than stock.
Old Mar 23, 2020 | 07:14 AM
Cadbury I agree about the issue or a pressurized line but air in the lines can to the same thing. And if the springs have to fight pressure from either one Ive seen even heavy duty race clutches burnt in less than an afternoon. The are dragging against each other constantly and creating heat and glazing not to mention wearing down.
Ive seen guys on the racetrack totally destroy a clutch in one 25 min race with this type of issue. (I doubt his is destroyed but it does not take much time to do it)
Old Mar 23, 2020 | 09:19 AM
MwCrf450R's Avatar
So I have already order a new slave, and a master rebuild kit. I'm planning to switch crankcase covers as the original has a crack. Idk if air got in through there or not cuz it never dries just always looks a little oily. So while I'm in there I'll check my discs, and if springs are that cheap I'll order some tonight and do those regardless while I'm in there. I dont quite remember for a fact what kind of oil I used but I'll make sure to do a deep cleaning while I'm in there.. I'd like to think I was smart enough to buy the proper oil but who knows
Old Mar 23, 2020 | 10:11 AM
You can also shim the springs with spark plug washers to account for age. Gives a better friction pressure.
Old Mar 23, 2020 | 12:12 PM
MwCrf450R's Avatar
you mean the new springs once I clean up my plates? Or the original ones?
Old Mar 23, 2020 | 12:55 PM
Either one really. At the racetrack if the clutch was slipping wed just shim the springs there since time is crucial. Either way it gives more pressure on the plates so stronger engagement and less slipping.
Old Mar 23, 2020 | 02:35 PM
MwCrf450R's Avatar
awesome thanks man I was all revved up to go riding but 50-60's and sun just turned into a week of snow, rain and Corona virus finally hitting my state perfect timeto tear the bike apart again Haha
JasChen
May 8, 2018 06:50 PM
Braymond
May 8, 2016 06:22 PM
sailorjerry
Jan 18, 2015 09:08 AM
trogdorsguitar
Nov 21, 2010 12:10 PM
RoofCleanPhenom
Apr 22, 2008 06:05 PM
