Chain Time
Old Jan 27, 2006 | 09:06 AM
Utah996's Avatar
Utah996
Chain Time
Well as spring gets closer I would like to start purchasing things I need to replace this year on my 2002 SH. I'm sure after 8000miles it needs little things. Chain, CCTs, oil change.
I need a new chain, where can I get one for a decent price or what do you recommend? I'm looking for a strong stock replacement. Thanks
Trent
Old Jan 27, 2006 | 01:53 PM
marmaladedad's Avatar
Hmm?
I ordered mine from Terra Powersports. (www.terra-powersports.com/)
I purchased a Regina chain. It's held up well so far. I would recommend changing your sprockets at the same time as the change.
Old Jan 27, 2006 | 02:36 PM
Utah996's Avatar
Utah996
What it the sprockets are in good shape? I dont want to change the gearing because I'm happy with the gearing as is. Anyone know how much stock sprockets are?
Old Jan 27, 2006 | 02:46 PM
Les's Avatar
Les
Les
Re: Chain Time
Are you sure you need a new chain? I've got 8k on my bike and have not even had to adjust the chain after it was adjusted at 2k miles. I'm not running around punching it or anything though. The chain is still in great shape on my bike. If you live in a dusty area you need an air filter. You might want to replace your plugs, oil and possibly coolant.
If your chain is worn then your sprockets are too and you should replace both at the same time.
Old Jan 27, 2006 | 02:48 PM
Utah996's Avatar
Utah996
I'm pretty sure the chain is a little warped...if you hold the rpms it has a lag/go, lag/go feeling. The oil is getting changed, the plugs were changed at 6000miles so their good. And the bike has a K&N already.
Old Jan 27, 2006 | 04:33 PM
thetophatflash's Avatar
Re: Chain Time
just replaced chain and sprockets. I also had the lag-go as you call it. It was also noticeable when adjusting the chain on a rear stand. There was a definite tight spot. Once replaced, the ride is fluid again. The tight spot was making sweepers a lot less steady.
Old Jan 27, 2006 | 06:01 PM
Hmm?
A set of front and rear sprockets, and a new chain, should set you back about $120-150. If your sprockets are close to new, then you can just get a chain. You may still get premature wear on the chain, though.
It's similar to changing the oil filter at every oil change or every other.
Old Jan 30, 2006 | 06:48 AM
Utah996's Avatar
Utah996
Awh excellent. So is there a good place to get just stock replacement sprockets or should I just go to the stealership for those?
Now where is a good place to purchase the chain?
Old Jan 30, 2006 | 08:07 AM
Hmm?
I buy my stuff through Terra Powersports.
Old Jan 30, 2006 | 08:09 AM
Utah996's Avatar
Utah996
I cant find the parts on their website. Guess I should just call them...
Old Jan 30, 2006 | 08:26 AM
Hmm?
Yes, try giving them a call.
Old Jan 30, 2006 | 09:54 AM
RVO27's Avatar
RVO27
Try ronayers.com for stock parts. They have an online micro fiche and stock part numbers. The shipping is quick as well.
Old Jan 30, 2006 | 10:44 AM
Loco's Avatar
Loco
There's also that guy on Ebay selling the 520 conversion chain and sprocket combo for around $125. Don't have his URL but just search for 520 conversion chain and you'll see his little gold combo deal, etc.
NZSpokes
May 2, 2014 08:10 AM
crtlv
Jul 7, 2010 12:00 AM
amhsraptor
Jun 12, 2010 08:10 AM
duran
Aug 27, 2007 07:57 AM
duran
Jun 4, 2007 10:38 AM
