New chain time, 520 or 530?
Old May 1, 2014 | 10:33 PM
NZSpokes's Avatar
Im in need of a chain and sprockets. So should I go 520 or 530?
I commute in all weathers everyday. But I do have a Scott oiler just fitted and I got over 30,000ks out of my last set which are still going strong on my old bike. I run 15/41 and am very happy with it.
Old May 2, 2014 | 02:21 AM
I went through this Dilema and in the end settled for the 530.
Mainly because I have snapped a chain once before and feel safer with the 530 although the weight saving with the 520 was attractive.
I currently have a new chain, sprockets and Cush rubbers waiting to be fitted but the current set with 28k is still o.k for now.
Old May 2, 2014 | 05:00 AM
HawkRider98's Avatar
Ran a 520 14/43 for years. Went stock on next change. When this wears out it will be 520 16/43. Had zero problems with 520 except for the 8 lbs of weight loss. I commute hour each way.
Old May 2, 2014 | 08:10 AM
What the others said. For commuting and generally less worry, I run 530. I only marginally care for my chain and it just wasn't something I feel necessary to try to cut back on. A lighter flywheel or rims will make a bigger difference. But if taken care of, a 520 will last a decent amount of time time and rotational weight does make a difference. Make sure to get steel sprockets, though, or a hybrid like a supersprox rear ring.
Rollin20z
Jan 28, 2013 02:42 PM
rrich49132
Sep 1, 2008 06:44 AM
davidhartley
Jun 24, 2007 03:16 PM
EngineNoO9
Jan 23, 2007 09:21 PM
SillyHawk
Sep 20, 2006 07:34 AM
