CCT changing. Urgent question
Old Jul 23, 2010 | 04:50 AM
Jens_denmark's Avatar
Jens_denmark is on a distinguished road
right now iam changing my cct´s i read all the articles about this, but wantet to be sure. i alligned the RT mark. and on camshaft spockets the RI and RE on each sides are as it should be, when changing rear cct.
I can see the piston are raised to the top, Is this right, should it be safe to change the cct now ?
Jens.
Old Jul 23, 2010 | 05:21 AM
slabm7's Avatar
Jens.
If you have the rear valve cover off, the lobes on the camshafts should be pointing up at each other at 45 degree angles. If either of those lobes is touching a valve then do not pull it. But if they are pointed at each other at an upward angle you will be OK. But to be sure you should zip tie the chains onto the sprockets.
Old Jul 23, 2010 | 05:32 AM
okies. thx :-P
skycam
Nov 29, 2023 08:57 AM
Tebs
Sep 4, 2012 03:06 PM
bluesman
May 30, 2012 10:14 AM
skycam
Aug 24, 2010 11:20 AM
AZZKIKER
Apr 12, 2005 09:04 PM
