carb shim mod... not as easy as it sounds
Old Apr 12, 2008 | 07:40 PM
Alpar's Avatar
Alpar is on a distinguished road
we did the carb shim mod on my buddy's bike (a kawi). it turned out to be fairly easy.... take of the gas tank, remove the air box and a couple of hoses, remove the needle covers, add the shim and put everything back together. took us probably like 20 mins.
it took us nearly 2 hours to do it on the superhawk... first off there is like 15 hoses and clamps that you have to disconnect to get the tank and the airbox off... some of which are not that easy to get to. to remove the needle cover on one of the carbs is damn near impossible unless you remove the entire carb setup... we ended up just using an angled screw driver, but even so it took us about 20 to get it off. putting everything back together sucked just as much... if not worse.
the improvement was noticable.... however unless you really know what you're doing or you have a lot of patience i don't recommend doing the mod yourself.
Old Apr 12, 2008 | 08:37 PM
cliby's Avatar
but.......the next time will only take you 1 hour, and the next time you'll dump all the PAIR stuff which makes fewer hoses, and then only take you 45 minutes, and the next time only 30 minutes total job............. you get the idea.
Syclone's Avatar
Boosted
patience grasshopper, just take your time and it's not so bad.
Old Apr 13, 2008 | 01:40 AM
Plus it is much easier to pull the carbs that to do it the way you did....
Old Apr 13, 2008 | 12:34 PM
gboezio's Avatar
Put a case of beer in your toolbox
Old Apr 13, 2008 | 01:15 PM
Alpar's Avatar
thats what i should have done... taken the PAIR stuff out !!!! maybe next time.
that case of beer in the toolbox is not a bad idea either.
Unzie57
Feb 3, 2013 05:58 PM
chemomche
Mar 11, 2012 07:33 PM
MessF4
Nov 24, 2009 05:14 AM
filter69
Oct 10, 2007 09:12 PM
ClevelandSuperhawkRumble
Mar 25, 2005 01:27 PM
