carb heater???
Old Jun 12, 2008 | 12:21 PM
codfish124's Avatar
SuperCock roster
codfish124 is an unknown quantity at this point
carb heater???
any one know why if any way some one would bybace the carb heater? any gain or lose is this? should i re hook back up? maybe it was leaking?
just bought a used supercock
Old Jun 12, 2008 | 12:32 PM
TheRezyReb's Avatar
TheRezyReb is on a distinguished road
MINE IS LEAKING NOW. Gotta get jome and fix it before bikenight toonight.
Old Jun 12, 2008 | 01:32 PM
drew_c14's Avatar
I'm lost...
Old Jun 13, 2008 | 10:22 AM
Fish's Avatar
My thinking on this when I did it, I was in a warm climate(San Diego) and the air temp plus the added temp of the coolant ment I was sending hot air in with the gas to burn. Cool air is better, so I rerouted the lines.
I could be wrong though on my thinking
Old Jun 13, 2008 | 10:36 AM
codfish124's Avatar
SuperCock roster
ya i read that it just for keeping the gas from iceing. i didnt know if it was for preheating the gas to atomize it better
on another note should i rerun a line to conect the 2 cooleant ports as the guy that did it jamed a bolt down the tube and clamped it off not leaking. i dont know if this bike has a pea hole on the tstat or if this acted as the pea hole. the bike dosent run hot or anything just want to make the bike work the best for a long time to come and not rig any thing.
Old Jun 13, 2008 | 03:41 PM
Fish's Avatar
I took the inlet hose(#1) off one carb and found where the outlet on the other was and traced it to the engine(#2). Connected hose between 1&2.
By the way, if your gas is icing up you have water in your gas. What happens in cold weather the moisture in the air is flowing through the carb at a good rate. It's that water that's in the air that'll freeze up in a carb.
00SUPERHAWK
Apr 20, 2012 04:45 AM
Tormoz
Dec 29, 2011 08:05 PM
captkirk
Nov 17, 2009 10:00 AM
