Carb Heater
Old Mar 19, 2012 | 09:35 AM
00SUPERHAWK's Avatar
Snap, Tap or Nap!!!!
00SUPERHAWK is on a distinguished road
Carb Heater
Has anyone ever bypassed the carb heater? Capping off the ports on the carbs and joining the two main lines together.
I have done it on cars here in FL, doesnt get cold enough to need to heat the carbs and we wanted the air charge to be as cool as possible coming into the TB/Carbs.
There have been debates about needing the fuel to be at a certain temp to atomize when being introduced into the cylinder. But with the radiant heat fron the engine I would think that would be enough.
I also ask this cause with the lean surge issue I am having I noticed it got worse and the bike got hot. So why have 190*/200* coolant running thru the carbs if its not needed.
Any thoughts?????
Old Mar 19, 2012 | 09:53 AM
8541Hawk has adamantly advised against this. The thermostat bypasses those lines once it has heated/opened up;
https://www.superhawkforum.com/forum...t-lines-26919/
Old Mar 19, 2012 | 10:03 AM
Thanks 7. Jumped the gun a little with my thread. Just got done reading 8541's thread on the system.
Hey off subject (kinda) you get a chance to read anymore on my other thread about my lean issue? Just wondering.
Thanks!!
Old Mar 19, 2012 | 04:27 PM
zxbud's Avatar
Heaters
Any thoughts?????
I removed them recently and notice no diff in performance. I did notice that I didn't have to reconnect them when reinstalling the carbs and that was worth it alone, notwithstanding never having to fool with them again. You are about 100 miles east of here and if your carbs ever freeze up I will walk to Melbourne and admit an error.
Also, a surge that increases as engine gets hotter is not a lean issue but a rich issue.
Old Mar 19, 2012 | 04:37 PM
Thanks!!
Not recently... been only getting glimpses of the threads... been a really busy week!
Didn't even think of that... and those things are on there TIGHT!
Old Mar 19, 2012 | 05:42 PM
Mine have been clamped off for like 7yrs now and I routinely ride in the teens F with no ill effects
Old Mar 19, 2012 | 05:50 PM
Might give it a try and cap them off an tie the two main lines togther. And if it has a ill effect then I can reconect them. Not a big deal.
Old Mar 19, 2012 | 05:53 PM
I just clamped them for the same reason, then just left them like that.
Old Mar 19, 2012 | 05:57 PM
Might be right. My pilots are the wrong size and someone had the fuel screws a good 3 turns out, but it is lean as wellin the mid to top. Mains are set up for high altitude. 172/175, dont know what idiot did that. I have the correct pilot 45 and main 178 on order. Fuel screws are set at 2 3/4 turns.
Thread- https://www.superhawkforum.com/forum...jet-kit-27753/
Old Apr 3, 2012 | 02:32 PM
Well since having the SH back together and testing out my carb setting and capping off the heater lines I havent noticed and thing bad by doing so. Bike is running good and I just need to make a small adjustment to my settings and I think I will be good. And as was said a few posts ago, I wont have to mess with those lines and getting them back on or off.
Old Apr 18, 2012 | 10:15 PM
Well like I always say, if you think there is no difference, try hooking them back up and then see what you think.....
I tried it in '98 and on my bike I thought it made no difference until I hooked them back up.... and I could feel the difference on the first ride.
So IMHO you should leave them hooked up
Old Apr 19, 2012 | 03:13 AM
I may do that just to see. I havent noticed anything bad to this point with them capped.
Old Apr 19, 2012 | 06:32 AM
8541, are you talking throttle response? What did you notice?
Old Apr 19, 2012 | 10:04 AM
Yes I am. On my bike it was "crisper" and took the throttle better with the line hooked up.
The best example I can give is that running without them was kind of like not having the TPS hooked up (though not as noticeable) in that the bike ran fine but was just a bit flat.
That is why I said to hook them back up, after running without them for a while and see if you can feel any difference. On mine I could but maybe others might not.
Old Apr 19, 2012 | 06:24 PM
OK after years of them blocked you have convinced me to try it. I wiil post results.
Old Apr 20, 2012 | 12:05 AM
killer5280's Avatar
Placebo effect.
Old Apr 20, 2012 | 01:08 AM
I will be interested in hearing what you find.
Old Apr 20, 2012 | 04:45 AM
Me too, might be diving into the Hawk this weekend, suppose rain all weekend. And Ill be working on cleaning up my wifes new "Used" find. A 83 CB550 Nighthawk "Bober". Its cool and rides nice.......Well thats a different thread.
Tormoz
Dec 29, 2011 08:05 PM
captkirk
Nov 17, 2009 10:00 AM
codfish124
Jun 13, 2008 03:41 PM
