brake squeal... possible problems?
Old Jul 22, 2006 | 12:54 PM
apbrian112's Avatar
apbrian112
hey guys, i just got done throwing some ebc hh pads on my hawk and i got this squealing during braking. the sound only happens during the last couple of seconds of the braking. what could be the possible causes? tia for the help.
-brian-
Old Jul 22, 2006 | 03:09 PM
SillyHawk's Avatar
SillyHawk is an unknown quantity at this point
i have the same problem when i brake...only on the front though.
Old Jul 22, 2006 | 04:54 PM
apbrian112's Avatar
apbrian112
yup, it's just on the front and it's quite annoying. ah well, the added braking power is worth it. did you use any brake pad lube on the backs of the pads?
Old Jul 22, 2006 | 05:56 PM
Just a note.. It's not really "lube” Some (most) of the noise (sequel) you get from brakes is caused by high freq vibration.. The stuff you put on the back of the pads is there to help dampen the vibrations. Some of the products do that by a glue like stuff that adheres the pad to the caliper or piston. Some of the stuff is a heavy silicone type deal that never really hardens.
Old Jul 22, 2006 | 06:53 PM
apbrian112's Avatar
apbrian112
yeah, i know that the squeal is from high freq vibes (learned from my brakes phase at UTI), i just couldn't think of a better way of putting it. do you know where i can get some of the glue stuff. i don't think the heavy silicone stuff works as well.
Old Jul 22, 2006 | 07:26 PM
Kendrick's Avatar
The Hypno-Toad
I just put the same pads on. They only squel when I first start to apply them though. They are after all sintered copper pads so some squel is probably inherent as they all essentially metal on metal. I also have EBC prolight rotor, I don't know if this may compensate for something so I only get an initial chirp. Either way they stop quick and my comments are of limited value, but with EBC rotors and pads it might work better. I don't know I'm not an engineer for them. Awsome stopping power though.
-Kendrick
Old Jul 22, 2006 | 08:11 PM
Scooberhawk's Avatar
Seņor Miembro, Ay Caramba
I'd take steel wool to the rotors. That would help with the squeal.
Old Jul 22, 2006 | 08:40 PM
SillyHawk's Avatar
steel wool...what kind? how course of a grit or whatever?
Old Jul 23, 2006 | 02:34 AM
shayne's Avatar
Fine sand paper will do the same thing, clean the rotors up. Racers do this all the time to put a bit of crosshatching back on them.
So a racer told me anyway!
Old Jul 23, 2006 | 03:51 PM
Yeah, or medium or fine steel wool. Too fine and it won't do anything. Coarse might not be bad, but you should stick with between medium and fine, unless you want to make a few passes with different kinds.
Old Jul 24, 2006 | 10:33 PM
SillyHawk's Avatar
well i had some of that metal fine grit sandpaper laying around...you know the black paper kind, so i decided to try it out. AMAZING, what a nice little tip. NO more squealing brakes!! thanks guys
smokinjoe73
Jul 29, 2012 10:18 AM
justinity
Oct 21, 2010 03:43 PM
iamanonymous
May 28, 2007 10:51 AM
Ausie996
Apr 21, 2007 04:13 AM
bluedog66
Mar 26, 2007 07:47 PM
