3 odd possible Problems
Old Oct 9, 2010 | 06:16 PM
justinity's Avatar
Über Member
#1 After letting go of the throttle it tends to stay at 3,000 rpm for 1-2 second then drops to normal rpms.
#2 When I sit at a light it knocks then drops rpms and stalls sometimes.
#3 I can hear a poof like noise from the front and it decelerates for that poof.
Old Oct 9, 2010 | 07:06 PM
#1 Is the throttle sticking, or is it after you actually turn the throttle back? I had a my throttle sticking before, it needed cleaning (the actual part that turns on the handle)
#2 Mine did this before I did my CCT's I can't imagine it was related, but after doing the swap it stopped. I think it probably just needed to get more riding time to clean out the jets.
#3 No idea, hopefully someone else has something to add here.
Old Oct 9, 2010 | 07:49 PM
NooB's Avatar
I loves me twins
Sounds like you have a vacuum leak. You might have an open vacuum port on one of your carbs, or your intake boots are loose or broken.
Old Oct 9, 2010 | 08:37 PM
What year is your VTR?
Old Oct 9, 2010 | 11:28 PM
justinity's Avatar
Über Member
2002 16,000 Miles
Old Oct 9, 2010 | 11:32 PM
justinity's Avatar
Über Member
Do you mean were the carbs mean the engine or the breather box?
I will check them out.
Old Oct 9, 2010 | 11:42 PM
It may be an intake leak but... I've noticed that 01 and up VTR's do not return to idle as quickly as the previous years. Why? I do not know for sure, but It may have something to do with the updated CDI & ECU for 01 and up VTR's. My VTR does the same thing and the two 2002's, 2003 and 2004 VTR's I've owned did the same thing as well. When I first got my '05 I chased that issue like crazy until I got another late model VTR an found it did the same thing
Old Oct 9, 2010 | 11:44 PM
justinity's Avatar
Über Member
#1 The throttle moves freely up top but I don't know about around the carbs
#2 I think I might have to change the CCT's then. I can hear noise from the chain or the guides or something. Were they easy to change?
#3 Pending
Old Oct 10, 2010 | 08:50 PM
There is a KB sticky on it here in the forum, and my signature links to a PDF I compiled from several sources including pics from when I did it.
It is easy, but don't skip any of the steps or you can damage things.
Old Oct 10, 2010 | 09:28 PM
motormouth's Avatar
Lubricate your cables and set your throttle cable freeplay to spec . per service manual (2-6 mm) . Just for starters .
Old Oct 21, 2010 | 08:37 AM
NooB's Avatar
I loves me twins
If you had a leak it would be under the butterfly's, or where the carbs meet the engine.
Any luck finding out whats wrong?
Old Oct 21, 2010 | 03:43 PM
dustinwild's Avatar
dustinwild
Are #2 and #3 related? Do they happen at the same time sometimes? If so some people call it carb backfiring, or burping. Most guys say a carb sync will fix it, or possible rejetting, and TPS mod.
Any mods done yet?
snowman666
Dec 7, 2008 08:31 PM
Zedicus
Sep 3, 2008 08:00 AM
Verne
Mar 11, 2008 02:19 PM
Anto
Jun 20, 2007 06:20 AM
apbrian112
Jul 24, 2006 10:33 PM
