RJL pads squeal
Old Jul 27, 2012 | 09:36 PM
RJL pads squeal
Not a high pitched squeak but kind of a low frequency hum just before stop. I tried removing and sanding the pads, resurfacing & sanding the rotor then going over it with a ball hone. After a couple days it comes back.
Havent had the issue with other pad. The RJL's are allegedly the best, most durable most powerful but I may have to change em out.
I tried the auto disc brake quiet but it just made a mess. I have heard they make backing pads to help but havent found them.
Old Jul 27, 2012 | 10:08 PM
Changing the pads will be the simple solution, what type of rotors you run on your bike? I'm assuming it's your street one.
Old Jul 27, 2012 | 10:27 PM
BeerHunter's Avatar
Slacker
If you have an old set of pads with the metal backing shims, try putting those on the new pads. Also, sometimes it helps to bevel the leading and trailing edges of the pads if they are not already that way from the manufacturer. If these 2 things do not help, a different pad compound is the best cure.
Maybe these pads are made to work with a different rotor alloy than what you have now?
Old Jul 28, 2012 | 05:37 AM
RJL pads on my bike with OEM rotors and F4I calipers do not squeal at all, never have. I can hear just a bit of noise / vibration from the drilled rotors / friction/ pad interaction as i come to a stop.. But that's it.
Old Jul 28, 2012 | 07:41 AM
Yeah beerhunter, I wish I could find those metal backing plates. All my cbrs had em but the ron ayers fiche doesnt show them so maybe they come with the pads?
Google has mentioned autoparts stores may have aftermarket backing plate material.
Old Jul 28, 2012 | 09:09 AM
They come with most pads... Usually they are also stuck to the pads with a bent over tab or similar...
Old Jul 29, 2012 | 10:18 AM
So I chamfered all the leading edges. Changes the sound of the moan but its still there. Gonna call around tomorrow for the ebc brake shims to solve it.
thedeatons
Jul 9, 2015 06:35 AM
mortbike
Aug 3, 2011 12:30 PM
iamanonymous
May 28, 2007 10:51 AM
apbrian112
Jul 24, 2006 10:33 PM
ZZRsouth
Jun 21, 2006 07:40 PM
