Bike is dead
Old Feb 3, 2013 | 08:05 AM
romile55's Avatar
romile55 is on a distinguished road
Bike is dead
Hello my name is Robert and I need some help. I know this might have been discussed before, but I cant find my exact problem. I went to get gas one day and the bike was running great. After I got gas I went into the store came back out and my bike wouldn't start. The lights and gauges will cut on, but that's it. No noise or nothing. I have no idea on what it can be. Thanks
Old Feb 3, 2013 | 08:56 AM
comedo's Avatar
There's a Service Manual available in the Knowledge Base. Section 21 deals with troubleshooting. There's also a good diagnostic chart at http://www.electrosport.com/media/pd...ng-diagram.pdf. You'll need a multimeter. Other people here will help you if you post more information.
Old Feb 3, 2013 | 10:22 AM
romile55's Avatar
Thanks for the reply. The bike is a 1998 it has a night rod headlight and aftermarket gauges and its been running strong. I did have a problem with the it cutting off when I put it in first gear, but it no longer does it. When I turn the key, the gauges and headlight cuts on, but nothing else. The neutral light also comes on and I cant get it out of neutral when I try to change gears.
Old Feb 3, 2013 | 10:58 AM
Wicky's Avatar
Try replacing the neutral switch
Old Feb 3, 2013 | 05:50 PM
+1 sounds exactly like your problem, change the switch and you will be set to go!
Old Feb 3, 2013 | 06:40 PM
zxbud's Avatar
Switch
Why would this switch be the problem?
Old Feb 3, 2013 | 09:14 PM
Just to clarify. The dash DOES turn on? The bike tries to start or doesnt. I got confused by you saying the power cuts which is off but then say on.
Old Feb 3, 2013 | 09:19 PM
superman_006's Avatar
superman_006 is on a distinguished road
If its the neutral switch.... It will crank/ start with the clutch pulled in
Old Feb 4, 2013 | 10:05 AM
But not if the wimpy little clutch plugs worked free like mine always do. Could be just the neutral switches connections since they arent hugely prone to failure.
Skidmarkart
Jul 11, 2014 05:49 PM
biggdadd58
Oct 24, 2013 12:43 PM
Aramis
May 12, 2011 07:28 PM
koth442
May 12, 2011 10:31 AM
EngineNoO9
Jul 1, 2006 09:13 AM
