BACKFIRE
Old Mar 26, 2008 | 06:56 AM
TheRezyReb's Avatar
TheRezyReb is on a distinguished road
BACKFIRE
Ok, I have a one off exhaust(free flowing). Bike runs great, but when I let out of the gas(no clutch)I get a few pops here and there. Sounds kinda like a lean condition. My question is, is this because of the different jetting between the 2 carbs? Should I worry about it?
Old Mar 26, 2008 | 07:08 AM
divingindaytona's Avatar
Remember stock is BAD!
First of all is the pair disabled. This will cause popping with aftemarket cans.
Secondly the popping on decel is a lean condition. The generally means that the bike is way lean. This is caused because both cards are running lean.
Old Mar 26, 2008 | 07:53 AM
MarineHawk's Avatar
A 1000cc V-twin is going to have a couple pops every now and then, with or without pair, it's just the character of the bike and not a bad thing at all. Of course, you can do everything DD just reccomended and probably take care of 95% of any pop the bike has, but beyond that, as long as it's not a consistent carb fart (vice exhaust hiccup), you'll be fine. Some of us even like it
Old Mar 26, 2008 | 08:02 AM
filter69's Avatar
Thats Mr Dill hole to you
so any why to get fire to shoot out when it backfires ? i think that would solve most of my "tailgating" problems around here.....
Old Mar 26, 2008 | 08:22 AM
TheRezyReb's Avatar
Sure, don't touch the clutch ,just hit the off switch, wrap the throttle a couple of times then cut the switch back on(do all of this as fast as possible), makes for a nice flame. I don't condon this, this can blow the cards out of the boots.
Old Mar 26, 2008 | 08:59 AM
drew_c14's Avatar
Like said before, check the PAIR. If it has already been removed check to make sure the caps are still in place.
You are on the money with being lean, just a mater of finding out why.
Old Mar 26, 2008 | 10:12 AM
TheRezyReb's Avatar
Not sure about the pairs system, the bike was set up when I bought it. I have a dyno sheet showing in the neighborhood of 118hp. However it was set up in Nebraska and I'm in Ms.
Old Mar 26, 2008 | 12:19 PM
drew_c14's Avatar
118...that's not bad at all
Old Mar 26, 2008 | 01:13 PM
MarineHawk's Avatar
Maybe at the crank.
Old Mar 27, 2008 | 07:08 AM
TheRezyReb's Avatar
ok, sorry new to these bikes. It has the two brother's block off plates, I assume this is means that the pairs system has been removed. I should mention that the muffler is only about 10 or 11 inches long.
Old Mar 27, 2008 | 08:52 AM
supermarto's Avatar
Mine was pilot screws being out of whack and my carbs needed a synch... I have had no loud reports since then.
brickbats
Aug 14, 2008 08:50 PM
LeanRider
May 17, 2007 02:31 AM
SuperHawkins
Jan 29, 2007 04:54 AM
MisterMohawk
Apr 28, 2006 07:34 AM
ClevelandSuperhawkRumble
Mar 13, 2005 03:09 PM
