BACKFIRE
Ok, I have a one off exhaust(free flowing). Bike runs great, but when I let out of the gas(no clutch)I get a few pops here and there. Sounds kinda like a lean condition. My question is, is this because of the different jetting between the 2 carbs? Should I worry about it?
First of all is the pair disabled. This will cause popping with aftemarket cans.
Secondly the popping on decel is a lean condition. The generally means that the bike is way lean. This is caused because both cards are running lean. |
A 1000cc V-twin is going to have a couple pops every now and then, with or without pair, it's just the character of the bike and not a bad thing at all. Of course, you can do everything DD just reccomended and probably take care of 95% of any pop the bike has, but beyond that, as long as it's not a consistent carb fart (vice exhaust hiccup), you'll be fine. Some of us even like it ;)
so any why to get fire to shoot out when it backfires ? i think that would solve most of my "tailgating" problems around here.....:evillaugh:
Originally Posted by filter69
(Post 157263)
Like said before, check the PAIR. If it has already been removed check to make sure the caps are still in place.
You are on the money with being lean, just a mater of finding out why. |
Originally Posted by divingindaytona
(Post 157257)
118...that's not bad at all
Maybe at the crank.
Originally Posted by drew_c14
(Post 157275)
Mine was pilot screws being out of whack and my carbs needed a synch... I have had no loud reports since then.
