APE CCT Adjustment?
Old 05-19-2007, 11:46 AM
njrider's Avatar
njrider is on a distinguished road
Question APE CCT Adjustment?
Installed the APE CCT's last night. Many thanks to all who have posted here with how-to's and tips - great forum. I adjusted the tensioners to finger-tight and then backed them out almost a full turn. Bike started up easily and runs with no strange noises so I think I'm good to go. A number of people have mentioned adjusting the tensioners with the engine running - I can see how I could do this on the rear which is pretty accessible, but what about the front cct? How are you adjusting this without removing the hose to the thermostat?
njrider is offline
Old 05-19-2007, 12:32 PM
trinc's Avatar
i had the lock nut backed off & adjusted it with an open end wrench - when happy with the position shut the bike down - removed the hose & tightened the lock nut.
tim
trinc is offline
Old 05-20-2007, 07:41 PM
njrider's Avatar
tim
Sounds like a plan. I was hoping there way a way to do it with removing the hose as I've already locked it down. So much for a lazy way out! Thanks for the help.
njrider is offline
Crashrat
10-11-2012 08:25 PM
Whittaz
03-25-2010 02:08 PM
joedirt5
03-04-2009 10:55 PM
Verne
10-03-2007 03:23 AM
thegreep
12-29-2005 11:33 AM
Quick Reply: APE CCT Adjustment?
