What swingarm will work???
Old Sep 4, 2012 | 08:35 PM
Twitch78's Avatar
Twitch78 is on a distinguished road
Hi all,
So I am in the last stages of modifying my bike. I have searched but have not come up with anything that points to a list of swingarms that can be fitted the easiest so I am throwing it out there for comments.
Any help would be appreciated from people who know what will bolt on, or fit with minimal conversion.
Cheers,
Paul
Old Sep 4, 2012 | 09:18 PM
saige's Avatar
the boss
try this thread out,this might get you going in the right direction.
https://www.superhawkforum.com/forum...rm-swap-17889/
the only other i would do is the single side swing arm,or just brace the stock swing arm.
https://www.superhawkforum.com/forum...ion-how-14544/
https://www.superhawkforum.com/forum...nd-swap-23466/
https://www.superhawkforum.com/forum...arm-mod-20391/
this should keep you busy lol
Old Sep 4, 2012 | 09:34 PM
If you want easy also consider bracing the stock swingarm with a brace off a 900rr swingarm. If you search you'll find plenty of info regarding caliper clearance, etc.
Old Sep 6, 2012 | 07:38 PM
Demon's Avatar
1 down 5 up
Demon is on a distinguished road
Will a 954 Swingarm work? I've been eyeballing by buddy's swingarm and I think it might? Anyone know for sure?
Old Sep 6, 2012 | 10:58 PM
You are just the third one this month to ask that question... So unfortunatley you get the reply that repeat questioneers get... SEARCH, and the answer will be apparent...
Old Sep 7, 2012 | 09:36 AM
JamieDaugherty's Avatar
No, not without major modifications. The shock is offset from the centerline of pretty much all bikes. The problem is the CBR954 is on the opposite side from the VTR. That means you would need to do serious cuttnig and TIG welding of the CBR swingarm to make it work.
Plus, and I assume you are talking about a new/better swingarm, anything you find will be longer than the stock VTR part. The VTR already has a wheelbase that is longer than ideal from a performance standpoint and going longer will make matters worse. Any gains in stiffness, rigidity, etc. etc. would be negated by the performance decrease of the longer wheelbase. Sorry!
Old Sep 7, 2012 | 01:52 PM
scottiemann's Avatar
just brace it... if you have a drill press a cutoff saw and a tubing bender you can get aluminum tubing from the local hardware store and make your own brace.
you can make it look as fancy as you want, it will be your own creation, is very cheap and you will get the performance out of it that you would get from a swap...
Old Sep 8, 2012 | 02:02 AM
erno's Avatar
erno
Just finishing up with my cbr900 swap
SloBlue
Jun 11, 2011 09:52 PM
mikstr
Apr 7, 2007 02:44 PM
Stumpy
Mar 10, 2007 05:04 PM
mikstr
Jan 8, 2007 05:56 PM
L-man
Dec 27, 2006 06:09 AM
